586,094 active members*
4,177 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Surfcam version 5 fails to install on Windows 7 64-bit computer
    Oct 2010
    7
    Dear CncZone members!
    I just recently replaced a ASUS P7M55 LE motherboard with a new ASUS P8Z77-V motherboard and I replaced also the Harddisks with WD Enterprise Edition 500 GB Harddisks. The RAID controller is a Promise FastTrak TX2300 and the RAID Array is a RAID 1 (Mirrored) Array.
    I tested the new motherboard thoroughly before replacing the old motherboard. The Windows 7 64-bit Operating System worked normally.
    I took the motherboard together with a Intel i3 3,3 GHz processor and the Hard Disks to the place where it is being used for CNC Machining yesterday. Today the fellow who run the CNC Machines and the computer told me, that he wasn't able to install SURCAM v 5.1 using that computer.
    I wonder, what might be the problem? The fellow is going to send me a photo that describes what the error message is, and then I'll know more about, what might have caused the problem, that he wasn't able to install Surfcam v 5.1.
    Looking forward to a prompt answer to my dilemma
    Smyans
    Apr 2003
    637
    I have versions 4 and 5.2 loaded on Windows 7 64 bit currently along with the current V6 on 2 computers. No problems loading these as long as you load it according to the instructions. I seem to recall they needed to be installed in the root directory not in the program folder. As for the hardware I don’t see where that should be a problem. I have mine loaded on a I7 and with SSD and a I5 laptop with a std hard drive.
    Oct 2010
    7
    Thank you for your answer.
    I just found out, that the major problem is the "Access denied" while the Surfcam installation programme is trying to open the "Cliconfg.exe"! The error is (0x5).
    I have tried to give sufficient rights for the installation program, but if has been of no avail thus far. I have even tried to use the "Takeown" command, but it hasn't helped either!
    What to do? How to get sufficient rights to install the program? I have tried with the Admin rights.
    Smyans
    Oct 2010
    7
    Smyans
    Oct 2010
    7
    It seems as the problem with the Installation of Surfcam Velocity 5 has been resolved. I just had to tweak the user rights so that the Owner was "TrustedInstallers" and the Administrator had full user rights etc.
    Anyhow thanks for your kind help.
    Smyans
  1. Surfcam and Windows 8
    By moldcore in forum Surfcam
    Last Post: 09-04-2013, 05:33 PM
  2. Post Processor won't install on Windows 7
    By logan1005 in forum BobCad-Cam
    Last Post: 06-15-2012, 04:02 AM
  3. SurfCam 6.1 with Windows 7???
    By lkenney in forum Surfcam
    Last Post: 06-03-2012, 10:17 PM
  4. SurfCam V4 and Windows 7
    By Chrliev in forum Surfcam
    Last Post: 03-13-2011, 07:26 PM
  5. GibbsCam install on Windows Vista
    By bender68 in forum GibbsCAM
    Last Post: 12-12-2010, 02:21 AM
