586,082 active members*
3,658 visitors online*
Results 1 to 7 of 7
    Apr 2013
    56
    Holding down material
    I am trying to engrave some of the 2 layer plastic to make some name plates. I have picked up some 1/16 inch thick material that is white and black. Now I am placing it on the table but it's not staying vary flat. As I am taking so little off, any materal that is not flat to the table will not cut right. What is the suggested way to hold this down to stay flat. The name plates are only 4x2 inches but the sheet is 24x48 inches. The table top I have is 24x24 inches in size and is made of MDF sheet. I have tried drilling some holes and screwing it down but this made this worse. Pls help. Thanks
    Dear,
    I think our company have one machine can fit you. SP6090.
    Our company is SPC Science&Technology Co,Ltd . And if you have any questions,feel free to contact me.
    My email is : [email protected]
    Alice yang
    Jun 2013
    1041
    Two sided tape has always worked the best for me. It won't work well with mdf so you will need to apply masking tape to the mdf then stick the tape to it. The best option for two sided tape I have found is to make a hdpe or polypro spoil board. The tape will peel off easily from it without tearing up.
    Ben
    Apr 2013
    56
    Thanks for the tape suggestion. I will give it a try.
    Nov 2012
    492
    I use magnets to hold everything from wood to Acrylic down they work great
    Quote Originally Posted by cncmadness View Post
    Sep 2013
    is your table a vacuum table?
    Whats the weather like today
    "buy one of our lasers"
    Isn't the conflict in Syria getting bad
    some people believe we didn't actually go to the moon
    my cat want's his dinner
    Anybody else see a pattern developing?
  1. Help with material purchasing. Should I base my dimensions on the material available?
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2012, 07:10 PM
  2. holding thin material on lathe
    By 40fordcoupe in forum MetalWork Discussion
    Last Post: 08-24-2011, 04:08 AM
  3. Holding torque Ncm vs Oz/in
    By Georgie in forum Stepper Motors / Drives
    Last Post: 12-14-2005, 09:58 AM
  4. Holding down material
    By swoolhead in forum DIY CNC Router Table Machines
    Last Post: 10-04-2005, 09:48 PM
  5. Holding Torque (please help)
    By dowling177 in forum Stepper Motors / Drives
    Last Post: 01-18-2005, 08:59 PM
