586,111 active members*
3,484 visitors online*
Thread: Enco Lathe
    Aug 2003
    75
    Enco Lathe
    Ok, I know I've seen the link out here.... but I can't find it to save my life!!!! where can I go to get the Plastic gear on the 9X20 enco lathe ?? It wiped out on me the other day.... too much usage I guess....... or is there a metal equivalent out there ?
    thanks,
    arthur
    779
    You should also have the metal gear with the Enco kit. I have it with mine. You can use it until you call Enco and order another one. The plastic one is there for safety reasons
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Aug 2003
    75
    Ah, now that you mentioned it, yes it is there..... thanks!! Enco just replied to my email.... $30.00!!!! for that plastic gear ?? I just assume make it out of aluminum, a little more rigid, but will still wipe out in the event of a jam up.
    thanks,
    arthur
    779
    Yes!! I have noticed that the after market parts from Enco are marked up about 500%
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Help me buy my first Mini Lathe
    By Highfly in forum Mini Lathe
    Last Post: 05-10-2005, 08:07 AM
  3. OneCNC XR Series Lathe CAD/CAM Released:
    By OneCNC in forum News Announcements
    Last Post: 03-07-2005, 11:20 PM
  4. Just got a taig lathe.
    By anoel in forum Mini Lathe
    Last Post: 01-18-2005, 11:29 AM
  5. Mastercam lathe crash course
    By CNCnUtZ in forum Mastercam
    Last Post: 09-26-2003, 07:03 AM
