586,390 active members*
2,841 visitors online*
    Jan 2004
    668
    Assembly Issue
    How to add part assembly points, such as where multiple gussets will go. Can I add points or what can I do make sure they go into the right places when each piece is a separate part?
    Feb 2009
    2143
    You will assemble the individual "pieces" in the assembly file using Mates. You can get the part in the "rough" right position using rotate and move, but the fine position will come by mating adjoining surfaces, telling SW what surfaces are parallel to each other (or perpendicular, or at what angle) as well as offsets, etc. Once the mates are sufficiently defined SW will let you know. If you over-constrain it will let you know that too.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Jan 2004
    668
    That's not exactly what I meant. If I want to add perpendicular members to an adjoining member and have no dimensions to reference. I want to say can I use points but that will not work any other suggestions?.
    Feb 2009
    311
    Can you post an example file?
    C|
  1. Assembly
    By cncadmin in forum EnRoute
    Last Post: 02-20-2012, 09:00 AM
  2. X5 Assembly help
    By JPowell in forum Syil Products
    Last Post: 08-07-2011, 10:51 AM
  3. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  4. Need help with assembly please
    By dpark1 in forum Solidworks
    Last Post: 07-26-2008, 03:43 PM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
