I am recovering from a computer and controller failure. I now have the machine setup and working exactly as before with one exception.
After running a g code the machine will return to zero normally. But after this I cannot move any axis or run new code until I push the 'Reset' button in Mach. Before the failure I was able to continue working with the machine without having to push Reset in between codes. My current controller is different from the one I was using before. Could this be the issue? This is my current controller: H5 Controller | Cau Cau
I have googled the issue and looked in Mach but so far I have no solution.
Any help is greatly appreciated!
Thanks!
Tomi
