Hello everybody i'm wondering if anyone has schematics or drawings/diagrams on how to build mounting brackets for some servo motors im going to be using on my retrofit
or alternatively if there is a place to buy these parts from
Cheers
Cheers
What servo motors are you installing?
Pritch
If you can find a Ez Trak that someone has taken apart, you could use there mounting hardware, They are not hard to make yourself, take say the x axes, one end were the handles are mounted, take it apart, Draw up the main bearing support housing, this is the main part, & is were you will make a mounting block for, You can also machine the front face of the Bridgeport housing & reuse it, attaching a plate to the front of it, & mount your motor on to that plate, a photo of a EZ Trak series II they have a cast housing, but you can fabricate something similar
Mactec54
