586,070 active members*
3,409 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > a good cnc router controller board!!
Results 1 to 6 of 6
    Jan 2011
    I am making a cnc router, and i have make a complett controller, all is working just fine, but emg switch and all the limit switches is not working. all the parts i have in that cabinett is some used that i got for free. i am thinking to get a new brake bord so work fine whit mach3. is it only made in china on the marked??? i need a link to some good bords.
    Tanks for help.
    May 2010
    313
    HobbyCNC | CNC for the desktop machinist and hobbyist.
    - - - Updated - - -
    www.hobbycnc.com
    Feb 2012
    117
    Quote Originally Posted by WoodSpinner View Post
    This is what I used. Pro 3 axis.
    Nov 2009
    4415
    The HCNC is a controller. He is looking for a breakout board I think. Try Cnc4Pc, PMDX, Keling, Gecko.
    Jan 2011
    Thanks, i think i wil change to cnc4pc, but i make my cnc router run. wen i have to highe fead rate x is getting hot and dont follow, its just standing and making a noice!! i think its the heat but i am not sure. its run fine if i set the fead rate down alot. i have 4,2 amp motors and 36V powersupply maby i have to have stronger motors and power.
    Oct 2008
    2100
    Steppers will draw power even when idling. Some controller boards will reduce current to the steppers when idling. Steppers can get quite hot when running continuously. Usually hot enough to be uncomfortable to touch, but not hot enough to burn you. Maybe even a little painful to hold firmly.
    Bob La Londe
    http://www.YumaBassMan.com
  1. Need a good cnc board firm/repairman
    By tac in forum Servo Motors / Drives
    Last Post: 06-14-2012, 04:51 AM
  2. easy-cnc mechatronics board good or bad?
    By 64dodge in forum Stepper Motors / Drives
    Last Post: 10-18-2011, 11:52 PM
  3. Hey Awesome board Keep up the good work...
    By AndreSimms in forum Community Club House
    Last Post: 04-05-2009, 08:28 PM
  4. Good 3-Axis driver board ?
    By deleteallusers in forum DIY CNC Router Table Machines
    Last Post: 04-11-2007, 04:59 PM
  5. HCNCPRO board good for these steppers?
    By mind_nl in forum Hobbycnc (Products)
    Last Post: 03-31-2007, 10:31 PM
