586,094 active members*
4,140 visitors online*
    Aug 2013
    Trouble running g-code
    I am working on a CNC Tormach. Every time I set my zeros on the 3 axis machine, then try to do a test run of my gcode, the spindle starts and moves about three inches then prompts me to reset. I know this can probably be hundreds of things, but does anyone have any tips? I am setting my x and y to the top left hand corner of my work using an engraving bit and the z is set to the top of the vice with work removed.
    very little information - but if it requests a reset maybe you're having trouble with electrical interferences???
    Is everything wired and grounded properly? Cables not unnecessary long?
    Christian
    My CAM Software and CNC Controller: www.estlcam.com
    Sep 2009
    624
    Post your code, and provide as much more specific detail as possible. What's your level of CNC/Tormach experience? (I ask because you have posted here only a few times, but recognize that you may have a half-century of experience!)
    Also: are you hitting one of the limit switches? That is, are you moving outside the machine envelope? Not clear which axis is moving from your note, but you could simply be close to a limit. Take a look at the max excursions screen, and be sure your table/head are positioned so that you don't hit a limit switch when you run the code. May require resetting your zero.
    Jun 2006
    3063
    Quote Originally Posted by JessinaDress View Post
    It sounds like you could be tripping the upper Z-axis limit switch during your tool change operation. Does that make any sense?
    Mike
  1. OSP500M-G Trouble running a large program
    By dansteinmetz in forum Okuma
    Last Post: 10-20-2012, 11:37 PM
  2. Circle Help Trouble getting the right code.
    By ibuildstuff4u in forum G-Code Programing
    Last Post: 12-29-2009, 04:49 PM
  3. Having trouble running keling 4030 drivers with emc2
    By OneAndy in forum LinuxCNC (formerly EMC2)
    Last Post: 01-26-2009, 02:03 AM
  4. post code trouble, or me?
    By Martin 007 in forum BobCad-Cam
    Last Post: 07-30-2008, 07:52 AM
  5. Trouble with DXF to G Code Transfer
    By mlapacz in forum SheetCam
    Last Post: 03-04-2007, 07:25 AM
