586,042 active members*
3,703 visitors online*
IndustryArena Forum > CAM Software > Mastercam > DIY router table adding 4th axis for making rollers
    Jul 2006
    24
    Hi all,
    I am trying to add a 4th axis to my DIY router table that will rotate around the X-Axis in order to make some simple roller wheels. My table is a typical gantry style running Mach3, and the A-axis (4th axis) will be very basic as I don't need to make anything more complex at the moment. I basically plan on adding a stepper motor with a mount attached to the shaft that I can mount some HDPE to in order to make some 1" rollers for another project. So I would like to be able to just move the Y-axis to the center of the HDPE and move the X-axis and Z-Axis to cut the profile as the A-Axis rotates under the bit to cut a wheel. I am having trouble trying to figure out how to add the 4th (A) axis to the machine definition, and making the whole thing work properly. I am self trained on MasterCAM X5 as my job does not give me training opportunity on the system but they allow me to use MasterCam when I like. I am fair at making 3-axis toolpaths but this 4th axis is confusing.
    If I had access to a lathe I think it would be easier to make the rollers but I do not know anyone with a lathe. Also it would be nice to learn how to do 4 axis machining for future use.
    Any advise would be great.
    Aug 2008
    406
    From what I understand most home made machines use a standard fanuc type post . Why not use a generic 4 axis post and control def .
    Jul 2006
    24
    Ok, So I am trying a Fanuc 4-axis post. The machine def seemed to stay the same and I'm not so sure its wrong for my DIY table. I have attached a picture of My definition.
    Attachment 200334
    So I am still trying to figure out how to make the wheel move under the tool. I have been experimenting with many different toolpaths and with the axis control in each but only once was I able to get the A-Axis to turn and it didn't do what I expected at all. Here is a screenshot of my latest test.
    Attachment 200336
    What would be the typical steps to create a toolpath that just runs the tool in a straight profile back and forth while the A-axis turns the stock beneath it? basically like a CNC lathe would do.
  1. LIMAC 2' x 3' cnc router for making sewing machine table
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 04-22-2013, 07:18 AM
  2. Adding a 4th axis to my router
    By ynnek in forum Mach Software (ArtSoft software)
    Last Post: 03-19-2012, 05:47 PM
  3. Starting a 4 axis CNC Router Table
    By Gir in forum DIY CNC Router Table Machines
    Last Post: 01-30-2009, 05:16 AM
  4. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
  5. Router Table 4th axis thought.
    By Bowman in forum DIY CNC Router Table Machines
    Last Post: 11-19-2005, 06:28 PM
