586,071 active members*
3,969 visitors online*
Results 1 to 8 of 8
    Aug 2005
    578
    3D Opensource Printer
    I figured I would come back into the scene ..As I havent been here for about 3 years. I began to have an interest in 3d printing so I figured I would give it a try. Especiall since I found this very affordable frame at a local business auction for $5. Frankly I think it has progressed my build to 50% as far as frame construction. just need to source some rails, stepper, and electronics... I hope to bootstrap this from scrap parts lying around except for electronics.
    Aug 2005
    578
    Well scored a bunch of old HP plotters... unfortunately after tearing into one of them I found there is not any usable parts for this build...not one rod or stepper... only was able to scrounge a belt and pulleys.. So disappointing..
    Aug 2005
    578
    next step
    Well I scrounged some nylon plate from a scrap bin at a local salvage. Piece is 1x4x12inches. so I have began to machine the x axis. I purchased some O-1 drill rod from Mcmaster Carr as it seemed to be the cheapest in my area. and I could get metric diameters. I had already purchased some LM8UU bearings and some LM10UU linear bearings so I am using them.
    Here are some pics of the beginnings of the carriage blocks so far. You will note i made it simple with a 45 degree slot in the block to hold the bearings and then drilled (4) 9/32 holes to accept the nylon zip ties. Spacing in those was 3/4 inch. I have assembled the x axis and it appears the 8 mm rod may be a bit too small as it flexes over the length I have decided to use. However I was surprised to see the bearing did not move at all after being tightened by Zip Ties....With this frame I can get about 24" of travel side to side, but will know for sure when it is assembled on the frame. These 80/20 1 1/2 x3 uprights will do nicely to firm it all up. and mounting the uprights will be a breeze. I drilled the holes for the rod at 5/16 Diameter and it is about the right size for a press fit of the 8 mm rod... well here are some pics
    Jul 2006
    122
    Quote Originally Posted by blackbeard52 View Post
    GREAT SCORE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
    - - - Updated - - -
    You have been bookmarked
    Aug 2005
    578
    looking back I could have made this a bit more user friendly for those not having a milling machine to cut the v slot. I noticed some 3/4 or 1/2 inch aluminum angle at the Home Depot that would accept these bearings if screwed on to the side of the blocks I already had...... making the need for a high end machine unnecessary. attaching the bearing could be the same by drilling the holes close to the edge and zip tying them to the angle. using this method you would only need simple tools like a hand drill.
    Additionally a router with a v groove bit could be used with a fence. using nylon or plastic for these assemblies opens up a lot of possibilities if you don't have access to a 3D printer for printed parts. After I complete this and begin printing I will produce a better looking printed part.
    Aug 2005
    578
    Electronics
    today I finished testing the electronics for the steppers and SD ram.. I cheaped out and ordered from Ebay / China the ramps board and drivers as well as the sdramps card.... after two days without any documentation I learned a valuable lesson. If you do not have experience in these type of areas its best to inquire about documentation before you order as the board had no printing in the areas for these connections. I have everything working now and the steppers and drivers are running very smooth. Below is a diagram of a ramps board that I used.. the manufacturer told me to put the sdramp on the AUX #2 (10 pin) jack but it actually goes on the AUX #3 (8 pins) with two pins not connected (black circles). I have drawn a square indicating the orientation in this upload. I also tested it using the Arduino Sketch Sdrampstest.zip (included below) to verify it was detecting the SD Sim card and configuring it properly. I was very surprised to see it would read the 32 gig micro SDHC I had installed as well as the 1 gig SD i already had.
    This diagram is the very same layout of my board but different manufacturer.
    Also for those who wonder about the power connection on 1.4 ramp board... according to many internet sources... the 11A and 5A connection can be the same power connection with jumpers across as long as the amps is sufficient to power the heat bed and extruder. And I tried it in this fashion and it worked perfectly for my test case... I used an old laptop power brick rated at 18v - 3 amp... However the amps are not sufficient to power the 3d printer. I have a pile of old PC power supplies that will become the source.
    here is a link for instruction on how to do it RepRage - How do you convert an ATX power supply to use with RAMPS 1.4?
    Aug 2005
    578
    Received some great Nema 17 motors Yesterday. here are the specs.
    These are nice 6 wire 1.8 degree stepper motors.
    Type 103H5208-0842 or -1241 or -0841
    NEMA 17
    Sanyo Denki
    STEPPER MOTOR, 1.8 deg 200 steps/rev when full-stepping
    PIN5 / RED = A
    PIN3 / BLUE= B
    PIN4 / YL = A-
    PIN2 / ORG = B-
    PIN1 / WHT = COMMON (not used)
    PIN6 / BLK = COMMON (not used)
    Description
    1.6 or 2.0 ohm motors
    Current per Phase: 1.2A unipolar .85A bipolar
    External Depth: 39mm
    External Length / Height: 42mm
    External Width: 42mm
    Frame Size: 17
    Holding Torque: unipolar 42.48 oz/inch (0.3N-m) bipolar 59 oz/inch (.42N-m)
    The Pulley has 15 teeth, 2 pitch, 7mm x 9mm diameter. A belt that came off this pulley has a number S2M100
    Note: Motor has colored wires as described above
    Aug 2005
    578
    One other notation on these motors... They have 4mm shaft..I was able to fashion a bushing to allow the 5mm to 8mm couplers by heat shrinking tubing to the shaft. turns out they are perfect fit now.
  1. Blender CAM - opensource CAM
    By iccha in forum Uncategorised CAM Discussion
    Last Post: 10-08-2014, 10:58 PM
  2. Your best opensource package ?
    By PyroEvil in forum OpenSource Software
    Last Post: 09-09-2009, 09:03 PM
  3. In-line opensource joystick
    By mvaughn in forum Open Source Controller Boards
    Last Post: 01-31-2005, 08:42 PM
  4. Opensource CNC
    By vacpress in forum OpenSource Software
    Last Post: 06-13-2004, 12:45 AM
  5. Opensource CNC
    By vacpress in forum DIY CNC Router Table Machines
    Last Post: 03-17-2004, 02:13 AM
