586,991 active members*
3,372 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Share Your Files Part or Art
Page 503 of 587 3403453493501502503504505513553
Results 10,041 to 10,060 of 11734
  1. #10041
    Re: Share Your Files Part or Art
    Any chance you get make this into a dxf file? I would greatly appreciate it! Click image for larger version.
  2. #10042
    Feb 2007
    4553
    Quote Originally Posted by billetbones View Post
    Please post a image of your finished project,
    Jeff...
    Attached Files Attached Files
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  3. #10043
    Jul 2012
    62
    Hoots Mon !
  4. #10044
    Oct 2013
    24
    Is it possible to take part of an image and convert it to a dxf file or file compatible with autodesk to engrave on aluminum on a tormach
  5. #10045
    Oct 2013
    24
    Here's a better detailed picture. Click image for larger version.
  6. #10046
    Jul 2012
    62
    Re: fire rings
    Try this.
  7. #10047
    Nov 2011
    21
    Can anyone convert this to a dxf?
    http://cdn.superbwallpapers.com/wall...-1680x1050.jpg
    Attached Thumbnails Attached Thumbnails snail-toilet-paper-20822-1680x1050.jpg
  8. #10048
    Apr 2014
    che
  9. #10049
    Oct 2013
    24
    Thank you
  10. #10050
    Quote Originally Posted by jalessi View Post
    Jeff...
    THANK YOU!!!!!
  11. #10051
    Oct 2011
    44
    Adam,
    Jeff...
    Here it is.
  12. #10052
    Feb 2007
    4553
    Adam,
    Very kewl, what type of machine are you using?
    How thick and type of material can you cut?
    Awesome work!
    Jeff...
  13. #10053
    Nov 2011
    21
    Quote Originally Posted by luiscarneirorm View Post
    Someone?
  14. #10054
    Jul 2012
    62
    Snail dxf, but it is a mess.
    You might be able to tidy it up but you will need a couple of hours.
    Good luck.
  15. #10055
    Apr 2014
    What software do you all recommend using to convert pdf's do dxf or dwg? I have two sketches I need converted.
    Thanks in advance for the help!
  16. #10056
    Feb 2007
    4553
    Quote Originally Posted by MidwestJeff View Post
    MidwestJeff,
    Inkscape is decent and you cant beat the cost, its open source.
    Draw Freely. | Inkscape
    There are several tutorials on YouTube
    https://www.youtube.com/watch?v=gdWWYZ27U-k
    Tutorial starts at the one minute mark.
    Welcome to the Zone,
    Jeff...
  17. #10057
    Apr 2014
    15
    Would someone be able to convert this to a .prt file for use in solidworks for me? I realize it's not a flat image but if someone could just get the ball rolling for me so I can make some adjustments it would be much appreciated! Thanks!Click image for larger version.
  18. #10058
    May 2007
    35
    Quote Originally Posted by AcesFull View Post
    NP. Is 2012 ok?
  19. #10059
    Feb 2011
    212
    thanks for post this up
    MidwestJeff,
    Jeff...
  20. #10060
    May 2007
    35
    Here ya go. Traced at the image size so it will need scaling. The sketch is not fully defined so adjustments can me made.
  1. Share your 3D Carving files, Parts or Art
    By yohudi in forum WoodWorking Topics
    Last Post: 11-17-2016, 08:42 PM
  2. Lada
    By multiple in forum MetalWork Discussion
    Last Post: 01-18-2014, 11:00 AM
  3. Lets Share!!!!! (cut files)
    By Dustin407 in forum Waterjet General Topics
    Last Post: 08-24-2011, 11:46 PM
