586,103 active members*
3,339 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Share Your Files Part or Art
Page 541 of 587 41441491531539540541542543551
Results 10,801 to 10,820 of 11733
  1. #10801
    Dec 2009
    19
    Re: Honda Logo
    Thank you Tweakie.
  2. #10802
    Jan 2011
    127
    Re: Share Your Files Part or Art
    thanks larry.. what bits do you use?? and do you use old coins or blanks??
  3. #10803
    Mar 2007
    463
    Quote Originally Posted by LS120 View Post
    The bits I use for finishing are like this
    10 x 0 5mm Titanium Nitride Coated Carbide Micro Drill Bits 1 8"" CNC PCB Router | eBay
    I use a .1mm for roughing, running them as fast as I can with my router (25000rpm) and just watch the feed to see how fast I can push it. As for the material, I have used old pennies, old nickels and old dimes as they are just base metal (you know what you have). I have done a lot of aluminum engraving 'cause HDs look great with stuff on the cases and brackets. Hope this helps you.
    One thing you need to remember is that with bits this small lubricant is a necessity and clearing the chips is a must, but be careful 'cause the brush can break the cutter! LOL
    Larry
    P. S. Practice and patience help, don't be afraid to try something,, the worst that can happen is your out $0.10 or so! :cheers: :cheers:
  4. #10804
    Jan 2016
    5
    anybody have this?Click image for larger version.
  5. #10805
    Can you do anything with this ?
    Tweakie.
    Attached Files Attached Files
    CNC is only limited by our imagination.
  6. #10806
    Quote Originally Posted by sergiocanojr View Post
    Can someone make this into a dxf for etching?
    tAttachment 302892
    I have absolutely no idea what a dxf for etching should look like, sorry this is the best I could do.
    Tweakie.
  7. #10807
    Jan 2016
    5
    thanks, that should work
  8. #10808
    Jan 2016
    5
    anyone have ducks unlimited? Click image for larger version.
  9. #10809
    Ducks Unlimited.
    Tweakie.
  10. #10810
    Jan 2016
    hi guys
    am new here
    I saw a file in .dxf for che famous photo
    I just cant find it any more
    if any body can help please
  11. #10811
    Is this any help (it is the cut-out for a vinyl sticker) ??
    Tweakie.
  12. #10812
    Jan 2015
    8
    Have anyone got any flame work in dxf or dwg that could share.
    Thank you
  13. #10813
    Mar 2007
    463
    Quote Originally Posted by jett99 View Post
    Thank you
    Try searching for flames, fire or words similar, you will find hundreds. Just look thru on both sides of the posts that come up.
    Larry
  14. #10814
    As Larry has said, there are so many available if you just do a search. In the meantime here is one little one.
    Tweakie.
  15. #10815
    Jan 2016
    thanx alot
    i still didnt figure out how this wibsite work
    so am sorry if my reply is too late
    you have been so helpful
    thanx
  16. #10816
    Mar 2007
    463
    Quote Originally Posted by SAMEER215 View Post
    thanx alot
    thanx
    Near the top of the page just below the page numbers is a search tab, use that to search this thread and you will find many DXF files that you can pick from. :banana: :banana: :banana:
    Larry
  17. #10817
    Dec 2010
    41
    Who can help me make a DXF of the two wooden planks underneath the image.
    Thanks in advance,
    YvesClick image for larger version.
  18. #10818
    Jan 2015
    8
    Thank you.
  19. #10819
    Quote Originally Posted by Yves.Gabriels View Post
    Thanks in advance,
    I think you have a lot of cleaning-up work to do but I have made a start on one of them
    Tweakie.
  20. #10820
    This is the Che vinyl sticker cut-out from the .dxf file in my post #10792
    Tweakie.
  1. Share your 3D Carving files, Parts or Art
    By yohudi in forum WoodWorking Topics
    Last Post: 11-17-2016, 08:42 PM
  2. Lada
    By multiple in forum MetalWork Discussion
    Last Post: 01-18-2014, 11:00 AM
  3. Lets Share!!!!! (cut files)
    By Dustin407 in forum Waterjet General Topics
    Last Post: 08-24-2011, 11:46 PM
