586,211 active members*
3,685 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Share Your Files Part or Art
Page 583 of 587 83483533573581582583584585
Results 11,641 to 11,660 of 11733
  1. #11641
    Jan 2012
    163
    Re: Share Your Files Part or Art
    Quote Originally Posted by space670 View Post
    Your welcome, happy to help.
    Have a look at post number #11591 further down in the thread.
    There I have explaind it a little.
    You use Inkscape
    Thanks you help me out alot!!! Gold Star for You!
  2. #11642
    Downloadable clip-art for May events such as Mother's Day, Memorial Day, Cinco De Mayo and We are open curbside pick-up only sign.
    Comes in different file types that you can import into your CNC software.
    Attachment 441756
    You can download the clip-art graphics at the file at link below.
    https://www.visionengravers.com/supp...-download.html
  3. #11643
    Here is a DXF of a Giraffe if any are interested :wave:Attachment 443594
    Attached Files Attached Files
    Multicam 300___Enrouter 4 PRO
    CNC 6040 Router Engraver Drilling and Milling Machine___Mack 3
  4. #11644
    Nov 2007
    154
    Does anyone happen to have a dxf file of a 1979 ford boss mustang, for cutting on laser?
  5. #11645
    Dec 2012
    192
    Hello.
    It is possible to get some designs googling for free patterns for hand quilting and embroidery.
    I´m sure you´ll get some good ideas from them. The included picture shows a simple design.
    In many cases you can get some form of file like SVG, DXF or others but it is possible to translate among them. It´s even possible to use programs like INKSCAPE to turn a JPG file into an SVG and then into a DXF file.
    Regards.
  6. #11646
    Feb 2007
    4553
    Question Re: Share Your Files Part or Art
    Quote Originally Posted by ryke View Post
    Ryke,
    Did you mean 1969 Boss Mustang? Please confirm year.
    Have a most awesome evening!
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  7. #11647
    Dec 2012
    192
    Hello.
    Given the appropriate distances a mill, an engraver or a laser cutter are just about the same thing as a quilter the only real difference being the tool.
    I see no reason why a pattern done for a quilter cannot be done on any of the aforementioned machines. Of course some code translation may be required but since it is possible to translate almost all quilting codes into dxf format that should not be a big issue.
    I think it´s worth looking at the following web page.
    https://www.etsy.com/mx/market/mustang_embroidery
    Regards.
    PS: in a laser engraver coloring can be changed for shading with a final result as watching a color image in a B/W monitor.
  8. #11648
    Picture of what you are looking for?
  9. #11649
    Nov 2007
    154
    Attachment 446066
    1970 not 79 lol
  10. #11650
    Dec 2012
    192
    Attachment 446066
    1970 not 79 lol
    Hello.
    This is just to give you an idea of the complexities of the conversion process. To avoid confusion I´m adding again the JPG file.
    I suggest you try this one out just to check that your machine is compatible with the format.
    While the conversion process from JPG to NGC is strightforward it takes quite some time as the conversion generates a miriad of small straight lines to do all the contouring. If fact that information is more of a NC nature than that of a CNC but is about the only way to do it, at least as far as I know.
    I had to scale the original file to about 25% as the converted file was nearly 8 times this size.
    I´d also expect the machining time to be rather long.
    If your machne is compatible try getting an image similar to the one I added and post it. I´ll try to get the conversion for you.
    Regards.
  11. #11651
    Here are 2 different ones, hope you can use any.
    Do show pictures of the finished piece if you can.
  12. #11652
    Nov 2007
    154
    Sorry for delay, here is the fire pit I made with the Mustang
    thanks for all the help
    Attached Thumbnails Attached Thumbnails Resized952020072395160516951536.jpg   Resized952020072395152831956699.jpg
  13. #11653
    Looks nice
  14. #11654
    Jan 2012
    163
    looks good
  15. #11655
    Nov 2012
    492
    can anyone help make a vector of the picture on the left side Click image for larger version.
Name:	OPeration Freedom Bird Logo.jpg
  16. #11656
    Mar 2007
    463
    Quote Originally Posted by Bigbird48 View Post
    It would help if you found a higher resolution picture to work from, this one is to pixelated to do much with except do a trace by hand which takes some time.
    Larry
  17. #11657
    Nov 2012
    492
    Yea Thanks Larry , This was sent to me by the American Legion Post Commander Post 1 PHX asked if I could laser engrave it. I told him it would be a tough project. I tried to do it by hand but my graphic skills suck LOL so I thought I'd ask here.
    Quote Originally Posted by Larry83301 View Post
    Larry
  18. #11658
    Mar 2007
    463
    They should have a much better file of the post's emblem as they use it for business cards and letterheads. See if they can send that one to you. Just looking around I found a picture with about 6 times the resolution as the one you posted and I'm sure you can do better than me as you are the one wanting it.
Name:	OPeration Freedom Bird Logo-2.jpg
    Larry
  19. #11659
    Feb 2012
    117
    Help needed. Can someone convert this? It's the best image I can find, no wording is needed. Thank you in advance.Click image for larger version.
  20. #11660
    Nov 2012
    492
    Actually this[ was sent to me from the VFW wanting to make a surprise plaque for this organization . So no I can't get a better image. but thank you for trying. Sorry about the delayed reply I never got a notification that you repliued ATTACH=CONFIG]449740[/ATTACH]
    Larry
  1. Share your 3D Carving files, Parts or Art
    By yohudi in forum WoodWorking Topics
    Last Post: 11-17-2016, 08:42 PM
  2. Lada
    By multiple in forum MetalWork Discussion
    Last Post: 01-18-2014, 11:00 AM
  3. Lets Share!!!!! (cut files)
    By Dustin407 in forum Waterjet General Topics
    Last Post: 08-24-2011, 11:46 PM
