Thanks weldtutor and quazga! This forum is a great tool. I will give these a shot.(flame2)
Switcher...Salute to you.. Your contributions in this forum is Priceless...
Khalid,
Thanks, :cheers:
Free DXF - vectorink.com
I dont know if it works on 3d... but there is also a plugin for converting DXF into CNC files...its called the Phlatscript. it was designed for a foam cutter that machines foam from the bottom... SO if you use this the Z axis has to be reversed in the code... but it is freeware... get it here http://www.phlatprinter.com/viewtopi...e5d209f42e972f works on version 6 and 7 of Sketchup as well as Swirchers plugin find.
Bob
Oh and by the way... a very nice video and instruction for this plugin is available on that site as well and some dandy file downloads
Bob
This might not be a knot!
Single line tool path, V-bit.
Inside cuts .125" deep, outer ring .160" deep.
Photograph is the file cut in MDF.
I am looking for drawings of miniature tables and chairs in order to make them in wood, well apart from the skeletons of dinosaurs, the cobra, gorillas and other, if someone were to go agradecere.
Hello,
I was wondering if anyone has a .dxf of a 6 player wahoo game. As always I have been trying to draw one up but can't seem to get it right. I am planning to make another WAHOO board that has a 4 player version on one side and a 6 player version on the other side. Here is a picture of a 6 player game. Thanks in advance.
This 6 player board should work for you & fit on the back side of the 4 unit one.:wee:
I'll be looking forward to another picture of this one.
Eight players might be a few too many!
Check this LINK posts #349 & #353 for several chair DXF's that could be scaled.
Thanks weldtutor but I want more of that kind, if they look for other pages.
Next Eiffel Tower.
Tower has been cut by water jet.
Stainless steel - 3mm thickness, hight - 183 cm
SMIECO
Do you have the DXF file that you could share?
I would like to try cutting one out of clear PLASTIC.
Dan
Dudes, I've been appreciating some of your work on here but many DXF files are not opening in AutoCAD.
Has anyone suggested a fix for this?
I would just like to take a little time and thank all for your help.
12 years ago I fell off of a 32 foot latter, landed on my back and spent a lot of time in a live in rehab unit, underwent about 8 operations and ended up in a power chair.
Today I am 73 and because of many wonderful people and over 1000 pm to many members I have a very nice CNC unit.
I was a custom cabnet maker and did hi-end remodel on baths and kithens.
Three years ago was the first time I even knew how to turn a computer on and did not know what a stepper motor or a DXF file was.
To start what some might saw, (a new life) at 70, is nuts) but it has change and help save my life. I am to undergo another operation on March the 27th. to help relieve the pain i have.
So again, thanks to all and I hope God will bless each of you as he has me.
Dan
This LINK will take you to a site to download Eiffel Tower DXF's.
