Here is a Divot Combo tool. I make it out of 14ga stainless steel. I sharpen the screwdriver edge and use it as a groove cleaner and screwdriver. The top part works as a spike wrench.
Divot Tool.dxf
Divot Tool.dxf
For the golf stuff
Bookmarks
You guys are great...and great stuff to share...I wish I had some to share also!!!
I know ..good things come in time!!!!!
Anyway my mother was looking for a Marry go Round out line, I thought I had saw one on the forum but I can't find it, eps, ai, cdr would work ,
Thanks to all that share their files.....
What program could i use to make a picture of someones face into lineart
like a cartoon or pencil drawing.
you could try Photo to Sketch
very good if you are looking at using it to clean up a photo before importing into some CAD programs to create DXF outline..
it is extreamly good at converting images to grey scale height fields
(See Attached)
thanks salty, just what i needed
or try inkscape it free www.inkscape.org
I'm a goin' fishin'
here's a file
Here is the HarleyGirl drawing posted earlier by another member. I've modified the drawing, removed the girl.
I drew this butterfly to use as a sail for my windchimes.
Heres the 1776 bell, flag and eagle made in inkscape
isis of egypt
Those are both, great myxpyklix!
THANK YOU
Mark
heres a chinese design that might be nice for a tabletop? made in inkscape
one more
Does anyone have any Basset Hound DXF files? My best friend past away and I want to do a tribute to him. I havent had any luck finding the right one.
Andrew
Andrew
Attached are a couple of drawings that might work.
Larry
Can anyone help me with a side view of a straight cut gear/cog. I have to make a presento for a retiring plant mechanic we have at work.
Carl,
I'm not sure what a "straight cut gear/cog" is, exactly. But, maybe the attached file will help. It is a cog that I modeled in Silo 3D from a tutorial provided by Andy Kinsella (Cinnsealach) and exported to DXF format. You may have some issues viewing, or using, the file since it is 3D, though.
I don't know if this helps, confuses, or is even the type of gear you're looking for, but here it is, nonetheless.
Enjoy,
HayTay
Don't be the one that stands in the way of your success!
