Thanks! What did you put in the search? I had no luck.
Looking for the Browning logo tried searching but no luck.
Thank you.
After doing a Google search to see what it is, it would probably be a copyright infringement. If you still wanted it being as you already have a picture of it, it would be better to draw up a fresh one in cad that way if it is slightly different it will be your design.
Could use some help getting some clean versions of these leafs....
Attachment 338596
Could someone help me convert this one to dfx? I want to cut it out on a plasma table.
Thank you.
File doesn't work. Loaded into the machine and the image is all broken up. Looks fine when I look at it on my autocad.
Does anyone have a .dxf plasma cut file for a Panda Bear? Thank You in advance!
Can pleas help me to generate the g code for my mach3 turn to use it in my cnc lath machine please?
so i got a dxf file off of here for the black hawks. i was wondering if there is anyway i could get someone to add something to it. im wokring on a school project and am using the schools laser but i havent learned how to edit/make/convert (if thats a thing) yet.but add the hammers as a background layout of the hawks head
Attachment 339118
BHawk.dxf
can anyone help me out and add the hammers as a background the hawks head, i got the hawks head from this site and thanks to who made it. thank you ahead of time for assistance. Attachment 339122Attachment 339124
Calminion,
Please make sure to post an image of your finished project.
Welcome to the Zone,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Trump portrait in the center of the Seal of the President of the United States.
DXF and SVG are in the zipped folder along with the proof and the portrait files without the seal.
Please post a picture if you cut.
Julie
http://robinhillmachine.com http://facebook.com/robinhillmachine
