586,096 active members*
3,677 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas vf-6 error code 149 spindle turning???
    Jul 2013
    32
    i am getting an error 149 spindle turning, and it appears that it is when the tool changer is trying to index the tool. this being said, we recently replaced the spindle encoder, and the new encoder required a couple value changes. we have been running for about a month since the change and now all of a sudden we are getting this error. can anyone help?
    Feb 2010
    1184
    Quote Originally Posted by millwright79 View Post
    What year is this machine?
    Does it have a Haas Vector Drive or another brand of spindle drive?
    When the encoder was replaced, were the belt and/or pulleys replaced also?
    I would check belt and pulleys for wear and verify that each are tight.
    Jul 2013
    32
    The year on the machine is 01/05? And yes it does have a vector drive. When we replaced the encoder, we replaced all belts and pulleys. I have just checked the tension, and all seems well. I have noticed that when the machine is sitting idle, the machine RPM bounces from 0 to 1, and once you spindle orient, the spindle has a constant vibration to it!
    Any suggestions?
    Jul 2013
    32
    we ended up changing the magnetic encoder, and reset the spindle orientation, this seems to have solved the problem.
    thanks.
  1. Haas HL2 Low Lube Or Low Preasure Error Code 121
    By fboling in forum Haas Lathes
    Last Post: 12-04-2012, 02:22 PM
  2. Chinese 2.2 kw VFD and spindle error code
    By AmparoTech in forum Maintenance DIY Discussion
    Last Post: 10-19-2012, 01:09 AM
  3. Spindle error code 35
    By Desertrunner in forum Fanuc
    Last Post: 04-22-2012, 10:56 PM
  4. 404 spindle error code
    By Michael Turner in forum Knee Vertical Mills
    Last Post: 02-08-2011, 09:41 AM
  5. Haas TM-1 Network Error Code 971
    By truline in forum Haas Mills
    Last Post: 12-21-2009, 05:52 PM
