There is a documented proven procdure for fixing the Haas stick spindle tapers. located here I hope this helps everyone out there with a Haas spindle.
I need to clear something up on this thread. I have worked for Spindle Grinding Service Inc for the past 22+ years. I have handled the calls that come in from the Wichita area. I have NEVER told anyone that their taper needed to be reground twice in 2 shifts. No spindle taper is ever going to wear in 2 shifts. If a machine is crashed and the taper damaged, then it will need more work. I have seen that, but NEVER have I seen a taper wear in 2 shifts. If this poster remembers me saying that, then his memory is faulty. We get many calls on sticky tools. We fix them by regrinding the taper back to proper specs. The main causes we see of sticky tools are these. Worn, bell mouthed taper. This is normal wear and happens to all tapers. Poor tool knockout. This is adjustable on most but not all machines. There should be a positive knockout of about .015". Heat. A spindle can get hot from an extended cut or improper cooling system. Put a cold tool in a hot taper and you have a stuck tool. Also the unclamp cylinder can have something to do with it. A bad seal can cause a lack of force at the end of the stroke. This could result in not enough force to knock the tool out.
As far as Haas goes, we don't see any more problems with those than any other machine. The spindles are no softer than others. The tapers are the same as any other steep machine taper. If the taper was the problem, then all should stick.
As far as the "fix" goes I have a couple of questions. What was done was effectively relieving the center of the taper. Why bother to bore the spindle and make a sleeve? Why not just relieve the existing taper? Also how much of the center did you relieve? The tapers are 2" long. How much contact do you have at each end now? One of the problems with relieved tapers is wear. Tapers bell mouth. Now once it bells past the front area of contact you have no middle. Shorter wear time between grinds. Also did the tools stick when the machine was new? Probably not or Haas would have been involved from day one. That means something has changed. What it it? Looks to me like you are fixing the symptom instead of the problem. There are virtually no machines built with relieved tapers. The huge majority of these run just fine. You probably have the only Haas machines with relieved spindle tapers. If that is indeed a fix, why doesn't every manufacturer make them this way.
Just my opinion, but I believe that I have learned a few things in my 22+ years and over 5000 taper regrinds.
But once more, make no mistake about it, Spindle Grinding Service has never told anyone that their taper was worn and needed grinding twice in 2 shifts.
Rocky Russell
