586,111 active members*
3,522 visitors online*
IndustryArena Forum > CAM Software > Mastercam > tapping problems
Results 1 to 7 of 7
    Apr 2011
    95
    tapping problems
    we have a 96 fadal VMC4020 with a cnc 88HS controller and are using mastercam x6 for solidworks
    we have recently began using tapping and have had limited success. we discovered that the feed rate in is correct but the feed rate out is 5.5% faster so therefore its breaking the taps.
    Dec 2008
    3109
    Quote Originally Posted by juniormachinist View Post
    ???? It's right...but it's wrong
    - Have you defined the tool correctly, put in the correct thread pitch ? ( pitch is what defines feedrate, not the Z plungerate. depends on your general output settings at the top of the post---- )
    - Does your NC file output the feed per rev.... or feed per minute ( G95/G94 ) ?
    - Is the RPM and feed/pitch the same in the Mastercam session & the NC file ?
    ( if not, the post may have a feedrate compensation for use with compression type toolholders, instead of a rigid tap holder )
    - attach your post ....change .pst to .txt so that it will upload to the zone
    plus
    put up some NC code for a M6 x 1.0p tap that is posted straight from Mastercam
    - & also the edited NC file that has been proven to work on the machine
    Apr 2011
    95
    our pitch is right. all the numbers in mastercam match whats in the nc code. it outputs g95
    i have attached the same file we were using which is a 8x1.25mm as well as a 6x1mm file
    Dec 2008
    3109
    Your post & tool settings appear to give correct NC code for rigid tapping
    - the problem would seem to be your machine, as it is NOT following the NC code
    I would start looking at the machine's parameters for tapping, there may be an incorrect feed adjustment in the parameters to the G84 cycle ( or the M29 component function )
    - it may have set-up for use with the compression type holders, normally they adjust to approx. 95% of the pitch (not 105.5% ), so, as you tap, the tool is pulled out further ( if the tap breaks, the holder springs back to it's correct length, or, for when the spindle reverses, it allows for non-synchronisation between the spindle & the Z axis )
    I worked on a fanuc, and assumed it had rigid tapping, found that the threads were stripping / stretching.
    - Problem was when the spindle slowed down to a stop, and reversed, the feed had actually stopped dead during that slow-down & reversal.
    - Fix was to only use a floating type tap holders, you can get the straight shank holders that use an ER11-ER16 collet to hold the smaller taps, it does mount into a sidelock or a larger ER32 toolholder. Also got a ER32 holder to be able to use the larger taps. There is a wide range to choose from. sample
    Apr 2003
    3578
    This is the format you really need for that control.
    Sample of my Post for the fadal I have used on that control for close to 10 years.
    TA,1
    O0001 ( TEST REV: )
    ( TEST )
    (MACHINE TOOL : FADAL FORMAT 1 )
    (DATE - 15-09-13 )
    (TIME - 13:02 )
    (MATERIAL: )
    (STOCK SIZE: X = 0. Y = 0. Z = 0. )
    (HOME POSTION COORIDNATES ARE THE FOLLOWING)
    (X= )
    (Y= )
    (Z= TOP OF PART)
    ( TOOL - 199 DIA. - .25 1/4-20 TAPRH )
    (USING FIXTURE OFFSETS: E1 )
    G0 G17 G40 G49 G80 G90
    T199 M6 ( TOOL - 199 1/4-20 TAPRH DIA. OFF. - 199 LEN. - 199 DIA. - .25 )
    G0 G90 S300.2 M5 E1 X-1.4147 Y-.0557
    G43 H199 Z1. M8
    G84.2
    G98 G84.1 X-1.4147 Y-.0557 Z-.5 Q.1 R.1 F300.2
    X-.2882 Y.6386
    X.9562 Y.0426
    X.8449 Y-1.1298
    G80
    M5
    G0 G49 Z0.0 M9
    G0 X0. Y0. E0
    M0
    M2
    ( BECAUSE YOU HAVE A CHOICE - )
    ( THANK YOU FOR CHOOSING PRECISION PROGRAMMING )
    Cadcam
    Jan 2010
    107
    I think we used M29 before tapping on our old fanuc machines..
    Apr 2011
    95
    Does changing the format mean that it chamges
    - - - Updated - - -
    Does changing the format mean that it changes weather its imperial or metric
  1. Tapping problems MV-40
    By bbarber80 in forum Mori Seiki Mills
    Last Post: 03-27-2012, 04:09 PM
  2. tapping problems.
    By fmcbrandon in forum Okuma
    Last Post: 05-29-2011, 02:49 PM
  3. TAPPING PROBLEMS
    By littlerob in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2009, 05:37 PM
  4. Rigid Tapping Problems
    By crazycnc in forum Fanuc
    Last Post: 06-10-2008, 12:39 AM
  5. Problems with tapping head.
    By Chuck Reamer in forum Tormach Personal CNC Mill
    Last Post: 11-12-2007, 04:16 PM
