586,103 active members*
3,030 visitors online*
    Aug 2010
    26
    Z axis build using CNC Router Parts.
    I am fairly new to CNC but I have completed the build of an MDF CNC machine and got it running. I realized my Z axis is in bad shape and decided to build the CNC router parts standard Z axis. My thought was that it will help me to slowly upgrade the other two axis to aluminum in due course. I got all the parts yesterday evening minus one little part. Cory at CRP was very helpful in discussing my need and guiding me to get the correct parts. I will document the build here for the benefit of other newbies like me and to get some feedback from the experienced folks out here.
    Here is what i am building
    Aug 2010
    26
    Finished tapping the extrusion and mounting the plate/rail and carriages. I was so surprised to see how simple and it was to get the tolerance set on the carriage bearings. Attachment 200924Click image for larger version.
ID:	200926Click image for larger version.
    Aug 2010
    26
    I went with CRP 5 start threaded rod and dumpster cnc anti-backlash nut.
    Attachment 200930
    I guess i made a mistake in ordering the extrusion. The plan call for 18.5 inch of extrusion and I ordered 18" extrusion. Now the bearing block and collar is tight. I think the the coupler is a bit above the motor mount.
    Attachment 200932
    Wondering what my options are. Do i move the steel rail .5" down or buy a new extrusion that is 18.5" long? Is it a problem if .5" rail stick out from the edge of extrusion?
    Aug 2010
    26
    I also realized that i have't ordered the High Z plate to mount the carriages. I was planning to mount this whole Z axis to my old router by bolting the high z plate to by y axis. So Z axis is on hold util i can resolve this.
  1. Dirks 4x8 CNC Router Parts Build
    By dirktheeng in forum CNC Wood Router Project Log
    Last Post: 03-17-2017, 06:54 PM
  2. Starting 48x96 cnc Router Parts Build
    By beachcnc in forum Open Source CNC Machine Designs
    Last Post: 10-31-2015, 01:24 AM
  3. CNC Router Parts Video Build Series
    By dirktheeng in forum Videos
    Last Post: 01-28-2013, 02:49 AM
  4. spare parts router build
    By ihavenofish in forum DIY CNC Router Table Machines
    Last Post: 05-06-2011, 09:12 PM
  5. build/buy cnc router for small rc parts
    By lokiwizz in forum DIY CNC Router Table Machines
    Last Post: 02-13-2009, 02:34 PM
