586,069 active members*
3,999 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Unrecoverable memory error
Results 1 to 11 of 11
    Aug 2010
    33
    Unhappy Unrecoverable memory error
    Hi there,
    VMC 15
    1998
    CNC 88HS
    Did not use the machine for about a month.
    When attempted to power it I got the following on the moitor:
    ======================SPACE BAR FOR NEXT MENU
    UNRECOVERABLE MEMORY ERROR AT 01CC
    USE THE 'NE' CMD TO CLEAR MEMORY
    However neither the controller nor the machine does not respond to pressing any key.
    Any suggestions ?
    Voytek1
    Jul 2011
    105
    FLASH : PM sent.
    FADAL VMC4020 HT 1995, Z 28" (if true) , 88HS , 10K rmp , 21 TC geneva /rotary/ , VH-65 (A-axis) ,3ph 400V , metric, NO conveyor, No palette. (+alternative DC AMP)
    Aug 2010
    33
    It is some more info on the problem.
    When first start the machine it shows :
    and then automatically scrolls endlessly the following:
    CLEAR AN EMERGENCY STOP CONDITION
    PRESS THE JOG KEY TO RESET THE EMERGENCY STOP
    AXIS CONTROLLER DOES NOT RESPOND TO NC
    When start for the second time it shows ONLY the message:
    Then stops and is totally non-responsive to pressing any key.
    Every think located on 1090 is non-responsive.
    Pressing the RESET button on the motherboard ( Slot 5 ) the display behaves as when first start the machine.
    Voltage on power supply (1220) is OK. ( +/- 12 V and 5.1V )
    Voltage on power to Keyboard (1090) (on J6 ) : 5.1V
    Neither key responds.
    I removed physically Keyboard from the machine: all is clean, no perforation on membrane under the keys, all paths are clean, no burnouts. I re-installed the keyboard on the machine.
    Behaves exactly the same.
    I re-sited all the cards including the main board after replacing dead battery (lithium 3.6 V from Radio Shack).
    When machine is ON pressing battery check button on the board ( Slot 5 ) lights up LED
    When machine is OFF pressing battery check button on the board does nothing.
    Removed all connectors and reinstalled them back.
    Tried to connect via laptop but it does not allow to open the device.
    On all axis boards in the enclosure there are blinking red LEDs.
    It looks like the machine was turned off during brief power outage, went into emergency stop mode
    and stays somewhere in limbo loop.
    Is there any way to get out of this loop?
    Is there any way to check if the Keyboard is OK?
    Is there any way to get out of emergency stop mode without using the JOG key?
    Aug 2010
    33
    September 20, 2013
    I fixed the memory problem.
    This is what I did:
    1- I removed an expanded memory board 1460-2A from 1400-5A and reinserted it into the slat.
    This stopped scrolling.
    2 – I zeroed the memory.
    3 – I reinitialized memory.
    3 - I and re-entered all parameters for my machine (SETP).
    4 – I and re-entered all 3 relevant backlashes.
    5 - Powered off CNC
    6 - Powered on CNC
    7 – Loaded simple program into memory.
    8 – Program runs with no problems.
    9 - Powered off CNC
    10 – I reinstalled an expended memory board 1460-2A to 1400-5A and reinserted it into the slot.
    11 - Powered on CNC
    12 – I repeated the steps 2, 3, ...... 8.
    Now I have a left over problem that I put in the new thread.
    Title is: “Can not access a jog menu using the JOG key”.
    Thanks every body who attempted to help me.
    Nov 2013
    Quote Originally Posted by voytek1 View Post
    I am having a similar issue, I know my battery needs to be replaced and thats the first thing Im going to do, do you know where it is located? Thanks.
    Nov 2015
    Re: Unrecoverable memory error
    I have the same error "ÜNRECOVERABLE MEMORY ERROR AT 8600' and the space bar nor any key respond. Any recomendations are very welcome. Thanks.
    Dec 2017
    kur galite nusipirkti daiktų?
    Dec 2016
    4
    Did anyone ever solve this? My old girl is doing the same thing ever since I unplugged the boards
    VMC 15
    1998
    CNC 88HS
    Any suggestions ?
    Voytek1[/QUOTE]
    Dec 2012
    192
    Hello.
    I´m not familiar with your machine but I have found that some memory boards rely on batteries to keep certain information. Perhaps it´s the source of your problem. I think it´s worth checking.
    Now, if it is, DO NOT JUST REMOVE THE BATTERIES. It might be possible that a certain procedure needs to be followed in order to replace them. I have seen controls left totally unusable by removing all the batteries at once.
    Note: the reason those controls were left unusable is not because of damage to the controls but because no programmer was found and no one knew what information was to be programmed.
    Regards.
    Aug 2009
    1573
    ...your battery is failing or has failed...most likely. than do a Zero Memory to clear out.
    https://www.fadalcnc.com/media/pdf/Z..._Procedure.pdf
    Mar 2018
    (SOLVED) Unrecoverable memory error
    Solved (without having to reinitialize the memory): I hope this may help others.
    We ran into the same issue, where after booting the Fadal up a month after the machine sat, we too had this displayed, “Unrecoverable memory error (at memory address _ _ _ _)”
    We resolved the issue by bring in a different program (uploaded it) into resident memory by way of the add-in expansion memory card we purchased and installed years ago. We found the memory card has been worth it’s cost due limited memory size and the unexpected occasional glitches along the way. (The expansion cards run about $700 each; but has saved our bacon numerous times).
    Although we backup to and retrieve (bring in) programs via this expansion card, I believe the approach of loading a program via the handshake through the serial port would help override whatever location in memory the Fadal is stuck at.
    The issue was resolved (after days of panic) and none of our programs were corrupted or lost. Should anyone need the brand name/company of the expansion card, reply and I will revise my submission.
    Below is the command line input we use with the particular expansion card we installed. The name of the program is arbitrary but I wanted to be thorough:
    CD,10
    TA,O_ _ _ _.FD2+
    (The PLUS symbol is required with that brand of expansion card. The “TA” signifies tape input)
    This is my first post and I hope this may help anyone in need.
    Dan
  1. unrecoverable memory error
    By Delw in forum Fadal
    Last Post: 09-26-2023, 12:40 AM
  2. unrecoverable memory error
    By Michael82 in forum Fadal
    Last Post: 10-14-2009, 07:46 PM
  3. Out of memory error
    By zachf in forum BobCad-Cam
    Last Post: 07-31-2008, 02:22 PM
  4. EMC memory error
    By tomekbrzozowski in forum LinuxCNC (formerly EMC2)
    Last Post: 07-03-2006, 09:04 PM
