586,409 active members*
3,064 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > SH-403 with MSG-501. Need set zero point for X-axis.
Results 1 to 9 of 9
    Mar 2013
    10
    It seems so easy, but...
    Par 1815 bit APZ=0
    Op.panel Set zero point - valid
    Select MPG and axis don't moves
    M31 (interlock bypass) don't executes in MDI mode
    Is there anybody who can help me with a good advice?
    Feb 2009
    6028
    Quote Originally Posted by coldrex View Post
    Par 1815 bit APZ=0
    Yes, make sure you cycled the door, then open and put in interlock release. (key switch)
    If you have other APC alarms ( like magazine or APC ) those will need to be set first.
    Check rapid and feedrate override is not set at 0
    Setting zero return valid in the custom/operators page is all you need if everything else is ok.
    Mar 2013
    10
    Do you mean door interlock release key?
    No result. Not any axis moves when I switc on Set zero point valid.
    What may it be?
    Feb 2009
    6028
    Is your atc home position light on? Do you have a pallet clamp signal on? Did you open/close the door? Are there any other axis alarms?
    Mar 2013
    10
    I have alarm 300 n-axis need zrn
    I opened/closed the door : it starts hydraulic
    Pallet is removed :clamp signal is off (all axis worked without problem earlier with I unclamped pallet)
    ATC home position I can check tomorrow
    In any case thank you for help. Maybe there will be new questions tomorrow.
    Feb 2009
    6028
    Without defeating the interlock, I would not expect the axis to move if the pallet is off. You now can't command an MDI M31 because you have the fanuc alarm.
    Mar 2013
    10
    Quote Originally Posted by underthetire View Post
    Thank you for help. I set pallet back and Set zero point works. In normal conditions you can mave any axis without pallet after M31 command. And pallet must be unclamped.
    Now I have a new problem - jammed B-axis. We have SH-403 with full 4th axis. I removed belt from B-axis but can't turn it with hand. M codes for 4th axis clamp/unclamp runs without any errors. May it be jammed inside the table or any other reason?
    May 2020
    5
    Re: SH-403 with MSG-501. Need set zero point for X-axis.
    i have alarm 730 on moriseiki sh 400. kindly guide me how to resolve it.
    May 2020
    5
  1. 5 axis entry point
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-21-2013, 03:36 PM
  2. How to move origin point on z-axis
    By anton_petrov89 in forum Esprit
    Last Post: 02-13-2013, 11:21 AM
  3. Replies: 0
    Last Post: 04-14-2012, 03:59 PM
  4. Replies: 2
    Last Post: 02-07-2009, 12:59 AM
  5. Z-axis 0 point (home) ?
    By tvdbon in forum DIY CNC Router Table Machines
    Last Post: 05-26-2008, 08:05 PM
