586,121 active members*
3,303 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Baldor Vector Drive Problems
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    May 2006
    17
    good news and you need some help from god
    there is now in Ebay one Baldor inverter the seller does not know
    that this part came from Fadal machine
    http://cgi.ebay.com/BALDOR-SWEODRIVE...QQcmdZViewItem
    if you will look at the part number you will see that it Baldor 175 the one that was befor the 180
    good luck
  2. #22
    May 2012
    4
    Hello Ferroma, I have the same problem you had. Could you get a solution? What was wrong in your Baldor vector drive?
    A technician checked my Baldor drive and found 2 cold welding and changed some components, but the problem is still there.
    I hope you can help me.
    Cheers
    Javier
  3. #23
    Apr 2005
    108
    First you need to tell us the type of baldor 170 175 or 180
    Then I can tell you how to make self test
  4. #24
    May 2012
    4
    Hi Dango,
    I´m not sure which model is. Its the Baldor large model. the inv-0039 part, VE003A03,CE-15HT and it´s similar like this:
    Baldor Adjustable Speed Drive Model No ID15H425 EO | eBay
    I hope you can recognize it.
    Cheers
  5. #25
    Apr 2005
    108
    From what I understand this is baldor 180
    In the keypad press
    Local then program
    Then go down till you see
    Level 2 block press enter
    Go down with the till you have on the screen
    Auto tunning press enter
    Then go with the arrow one up
    Then answer all the time yes
    If there is problem it will tell you in the way
    You can download Fadal manual
    And there is there auto tunning
  6. #26
    May 2012
    4
    Hi again Dango,
    I´ve maked the test and it says "Test Passed". But I can´t make the test when the baldor drive fails becouse the keypad screen is crazy and I can work with it.
    I think there is a component that fails sometimes but if it´s not broken it´s very dificult to find.
    I´ve find too a "low Init Bus V fail", but I don´t know if this is the reason of the problem.
    If you have any other ideas, please tell me .
    Cheers
  7. #27
    Re: Baldor Vector Drive Problems
    Hi, please, tell me the value of this resistor. I need to know the ohms and power.
    Regards.
Page 2 of 2 12
  1. Replies: 21
    Last Post: 09-04-2015, 02:36 PM
  2. Baldor vector drive 0045 blown cap
    By dougputt in forum Fadal
    Last Post: 10-18-2012, 04:14 PM
  3. vmc 15 baldor drive inop
    By donnelson in forum Fadal
    Last Post: 03-25-2009, 08:43 PM
  4. New Spindle drive (baldor)
    By Lonewolf32 in forum Fadal
    Last Post: 07-13-2007, 06:32 PM
  5. Baldor Vector Drive Problems
    By MetalTech in forum Fadal
    Last Post: 12-10-2005, 03:38 PM
