586,112 active members*
3,173 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 6 Cant find hidden parameters
    Sep 2006
    296
    I reinitialized my BMU board and reentered parameters and settings but i cant figure out how to access the "hidden parameters". I wrote down instructions for myself the last time i did this but aparently i left a step out on exactly how to get to the hidden pm's. Probably forgot to write down "stand on left foot while pushing P and close one eye". I swear these old machines drive me crazy.
    Any Fanuc guru's out there to assist?
    May 2013
    128
    PARAM_INFO BIT_NO DESCRIPTN KEY
    PARAM 000 1 T/M CIRC. INTER BY RAD.
    PARAM 000 2 T/M ADD 16 OFFSETS MEMORY
    PARAM 000 4 T/M CSS B (ANOLOG OUTPUT)
    PARAM 000 5 T/M G20/G21 SWITCHING (INCH/METRIC)
    PARAM 000 6 T/M REF. POINT RET'N (2ND) 6M 0 RETURN B
    PARAM 000 7 T/M REF. POINT RET'N (1ST) 6M 0 RETURN A (MANUAL,G28
    PARAM 001 0 T/M G90,92/94 CYCLES 6M ADDITIONAL AXIS @SIM CONTROL
    PARAM 001 1 T/M AUTO TOOL COMP. 6M ADDITIONAL AXIS CONTROL
    PARAM 001 2 T/M CHAM. AND CORNER RADIUS.6M SIM. 3 AXIS CONTROL
    PARAM 001 3 T/M TOOL NOSE COMP. (RAD). 6M CUTTER COMP C
    PARAM 001 5 T/M MULTI CYCLES. 6M S2/4-DIGIT BCD
    PARAM 001 6 T/M M.P.GENERATOR
    PARAM 002 0 T/M AUTO ACCEL/DECEL. FOR FEED
    PARAM 002 1 T/M STORE STROKE LIMITS 2 AND 3
    PARAM 002 2 T/M RADIUS PROGRAMMING 6M F1 DIGIT FEED
    PARAM 002 3 T/M STORE STROKE LIMIT 1
    PARAM 002 5 T/M ** TAPE INTERFACE
    PARAM 002 6 T/M INCREMENTAL OFFSETS
    PARAM 003 1 T/M G10 OPTION 6M OFFSET DATA FROM TAPE
    PARAM 003 3 T/M ** ISO INPUT
    PARAM 003 4 T/M CLOCK DISPLAY 6M RUN HOUR DISPLAY
    PARAM 003 5 T/M RAPID TRAVERSE OVERRIDE
    PARAM 003 7 T/M PC MODEL B.
    PARAM 300 0 T MACRO A OPTION
    PARAM 300 1 T MACRO B OPTION
    PARAM 300 2 T RESTART IN PROGRAM
    PARAM 300 3 T G31 SKIP (NO MOTION)
    PARAM 300 4 T AUTO CO-ORD. SETTING.
    PARAM 300 7 T ADDN. BLOCK DELETE
    PARAM 301 1 T/M MESS DISPLAY.6M EXTERNAL DATA I/P, ALARM MSG
    PARAM 301 2 T/M 80/320M MEMORY (PART PROGRAM STORAGE) 6M 125 PGM
    PARAM 302 1 T/M VAR. LEAD THREADCUTTING 6M G60-UNIDIRECTION POSN
    PARAM 302 2 T DIRECT I/P OFFSET VALUE
    PARAM 302 3 T MIRROR IMAGE.
    PARAM 302 6 T WORK CO-ORDINATE SETTING
    PARAM 302 7 T OFFSET VALUE COUNTER I/P
    PARAM 304 2 T TOOL WEAR/GEOM.
    N0100 T/M SOME OPTIONS REQUIRE ADDN PROMS-MACRO
    N0090 T/M SOME OPTIONS REQUIRE ADDN PROMS-TOOL WEAR/GEOM.
    N0110 T/M BOARDS- MEMORY OPTIONS
    N0019 T SETTING PARAMETER
    N0020 T/M 1)PARAMETER WRITE ENABLE SWITCH "ON"
    N0021 T MODE SWITCH TO "MDI" OR ESTOP STATE
    N0015 TO CLEAR MEMORY POWER ON 'O'AND 'DELETE'KEYS
    N0022 T HAND LOAD PARAMETERS 0- 4
    N0023 T HAND LOAD PARAMETERS 300-302
    N0024 T HAND LOAD PARAMETERS 310-313
    N0025 T HAND LOAD PARAMETERS 340-341
    PARAM 000 0 6M CIRCULAR INTERPOLATION STD G02 G03
    PARAM 000 3 6M SPINDLE SPEED 12 BIT OUTPUT CSS A
    PARAM 001 4 6M CUTTER COMPENSATION B
    PARAM 001 7 6M TWO DIGIT DESIGNATORS T2/T4 TOOL FUNCTIONS
    PARAM 002 7 6M EXTERNAL DECELERATION
    PARAM 003 2 6M HELICAL INTERPOLATION
    PARAM 002 4 6M THREADING AND SYNCROUS FEED
    PARAM 003 0 6M PART PROGRAM CHECKING
    PARAM 003 6 6M STORED PITCH ERROR COMPENSATION
    PARAM 004 0 M TOOL LENGTH COMP. (G43,G44,G49)
    PARAM 004 1 M TOOL OFFSET (G45,G48)
    PARAM 004 2 M CANNED CYCLES B (G73,G74,G80-G89)
    PARAM 004 3 M CANNED CYCLES A (G80,G81,G83,G84,G85,G86,G89)
    PARAM 004 4 M CIRCULAR CUTTING
    PARAM 004 6 M SND AUXILARY FUNCTIONS B-CODE 3 DIDGITS
    PARAM 004 7 M REMOTE TYPE POSITION DISPLAY
    PARAM 005 0 M EXTERNAL WORK NO. SELECT
    PARAM 005 1 M
    PARAM 005 2 M
    PARAM 005 3 M TURRET INDEXING FUNCTIONS
    PARAM 005 4 M FT CENTRE H ATC SPECIAL ATTACHMENT
    PARAM 005 5 M FT CENTRE D/E ATS SPECIAL ATTACHMENT
    PARAM 005 6 M ROBOT INTERFACE
    PARAM 005 7 M NIBBLING CYCLE (WOODPECKER)
    N0009 CONTROL
    N0011
    N0016
    PARAM 004 5 M SCALE FUNCTIONS (MAGNESYNE-OPTISYS)
    N0026 ** CHECK SETTING DATA ISO/EIA ETC. **
    N0026 T/M
    PARAM 300 6 M 3RD/4TH REFERENCE POINT RETURN
    PARAM 300 5 M TOOL LIFE MANAGEMENT CONTROL
    PARAM 301 0 M AUTOMATIC OVERRIDE
    PARAM 302 0 M WORK COORINATE SYSTEM SETTING - G54-G59
    PARAM 000 3 SPINDLE SPEED 12 BIT OUTPUT CSS A
    PARAM 005 1 M
    PARAM 005 2 M
    N0009 CONTROL
    N0011
    N0016
    N0026 T/M
  1. Mazak QT10 T2 "hidden parameters
    By CNC Machine OT in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-29-2014, 07:05 PM
  2. Fanuc 10t hidden ladder
    By lz2fv in forum Fanuc
    Last Post: 01-29-2013, 07:27 PM
  3. Fanuc 21i parameters hidden
    By FalconerBR in forum Fanuc
    Last Post: 01-22-2010, 10:52 AM
  4. Fanuc 18i-TB Unlock hidden parameter
    By newckl in forum Fanuc
    Last Post: 08-28-2009, 03:11 PM
  5. M2 hidden parameters
    By swhitejhr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-03-2007, 06:22 PM
