Re: origins / UCS maybe, in autocad 2007
hello ger
Don't draw in Paperspace if you plan on using the drawing for CNC use. Always use Modelspace only
It worked so far, so why would i change it now ? i do not say that "what you say" won't work, but if i wount be able to fix this, i will delete autocad and all dwg/dxf/etc files from that computer, and re-install
And try using Copy with Basepoint, and specify the location when you paste the cop
I use ctrl+c/v when copying entities from one file to another ; ofcourse, i use basepoint inside the file ( inside the paperspace / modelspace )
the reason why i copy between files : i only copy the necessary entitites ( toolpaths that i wish to export ) to a file that is empty, so when i save it as a dxf, it contains nothing else this dxf file is read by a G code generator, and thus, i have my codes and i sent them to the machine ... of course, i could upload the file into the cnc, but it would be much slower
You see mr ger, i did not have time to learn a CAM, so i extract what i need from the CAD and convert it to a program for the machine, through a G-code generator
ps : such medals, like yours, do they come into different colors & shapes
