586,217 active members*
3,442 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > GibbsCam solid problems
Results 1 to 10 of 10
    Sep 2013
    5
    Hello!
    Wondering why I get so many circles when I extract the profile. What is wrong?
    Regards / Markus
    Attachment 201516Attachment 201518
    Feb 2011
    80
    may have to explain more............I am not seeing extra circles. Also try the Gibbscam forum at Gibbscam.com. You will get a good response there
    Sep 2013
    5
    sorry! I was very stressed: (
    I mean what you see on picture # 2, there are two pieces radius ought marked with four points each. Gibbs draws about twenty pc points where there should be six points: (sorry the pictures were so bad.
    Sep 2013
    37
    It looks like you extracted the profile from the solid. When the solid was built it has very minor errors in it, of which Gibbs is showing . You are going to have to pick the lower two points on the profile and redraw the radius you need.
    Sep 2013
    37
    Sorry I am on my phone and did not see the first photo. You can also go into you preferences and adjust your setting on the solid. Change it to .001 the rendering will be slower, but the solid resolution is much better. You can get to it by right clicking on the solid in your body bag. My first suggestion might be easier.
    Sep 2013
    5
    Thanks so much!
    Will test on Monday. It's very strange because I have tested the solid on a total of 3 different computers but only one of them things go wrong
    Regards / Markus
    Sep 2013
    5
    Nope: (
    The same problem remains: (I can not believe it works on two of three computers: (
    Sep 2013
    37
    Mmm, strange. Go to the Gibbs website and go to the support tab. They have a forums board there just like CNCZone. They are super helpful. You can even send them your VNC file. Nice feature.
    Nov 2009
    45
    When you extract the geometry change your Geometry extraction tolerance to .0005 or something other than Zero.
    Sep 2013
    5
    Hello!
    I usually run with 0.01 mm tolerance. I have done experiments with increasing tolleransen 0.01 at a time. When I get to 0.07, everything starts to look good. but the radius is wrong, 1.159 instead of 1.2mm .
  1. Help with gibbscam
    By scojoes in forum GibbsCAM
    Last Post: 12-13-2012, 05:48 PM
  2. 2 gibbscam needs in NC
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 11-11-2011, 10:17 PM
  3. SW Solid to MC problems
    By SScnc in forum Mastercam
    Last Post: 07-22-2011, 03:27 PM
  4. GibbsCAM
    By MagTDK in forum Uncategorised CAM Discussion
    Last Post: 09-24-2006, 06:57 PM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
