586,103 active members*
3,331 visitors online*
    Jul 2005
    86
    Bending Aluminum Bar
    6"wide, 1/8" thick
    Want to make a nice sharp 35 degree (not 90) corner, will most likely use a press. Any problems here? Ive never done aluminum before. Is it gonna break in a half or what or can i expect it to bend nice like mild steel? Should I heat it up first?
    Jul 2005
    12177
    It depends on your alloy and temper. With 6061 T6, which is the most common, you should be able to do 35 degrees over a bend radius about 1-1/2 to 2 times the material thickness. Other alloys or a lower temper will allow tighter bends but they are not as strong.
