586,745 active members*
5,994 visitors online*
Results 1 to 6 of 6
    Feb 2009
    23
    Heidenhain TNC 150 B Drip feed
    I've just received my new toy, a Bridgeport series 1 interact. It has a TNC 150 B controller. Can this machine be drip fed?
    Jim
    May 2013
    128
    yes the machine can with a third party software
    Sep 2003
    72
    You can download TNC Remo from the Heidenhain website and use it to drip feed your control. It is free and is compatible with all Heidenhain controls.
    Feb 2009
    23
    Thanks for the replies.
    I am trying to machine parts I've drawn in solidworks.
    I have installed TNC remo, but I'm unsure on what type of files it's looking for? I beleive that the TNC 150B does not use G code, so what language does it use? What do I need todo to convert a solidworks part into a file to send to TNC remo??
    Sep 2003
    72
    If I can recall correctly, you should be able to use G code with the TNC150B. Control needs to be switched over to G code. You can do this by pressing MOD keys several times until you come to programming and then chnge to g code instead of conversational programming.
    TNC remo will look for files ending with .H, thewrefore your G code programm should always end with .H and not .NC or anything similar. Did you set up TNC remo for your control TNC 150B?
    - - - Updated - - -
    Nov 2012
    70
    As far as I know you can´t use G-code on TNC150 neither can you drip feed (blockwise transfer) on this control. These features came with the TNC155
  1. Heidenhain TNC145 - drip feed
    By Sheepspeed in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2013, 06:10 PM
  2. Drip feed of heidenhain TNC 370 on Bridgeport 560/22
    By poddie in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2013, 07:23 PM
  3. Drip feed on Heidenhain?
    By imachecknician in forum Uncategorised MetalWorking Machines
    Last Post: 09-28-2010, 10:27 PM
  4. Heidenhain TNC 355 DNC drip feed
    By jake_tb in forum DNC Problems and Solutions
    Last Post: 08-05-2010, 08:13 AM
  5. Drip feed from PC to Heidenhain
    By moorejc in forum Bridgeport / Hardinge Mills
    Last Post: 02-03-2009, 04:57 PM
