586,913 active members*
2,794 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Best servo drive with tuning software for my DC servos?
Results 1 to 6 of 6
    Dec 2012
    102
    I'm gathering parts for my 4' x 8' CNC router build. Who makes a good drive with tuning software that would be a good match with the following DC servos?
    X & Y axis servos - NEMA34 1125 oz/in Dual Shaft DC Servo (KL34-180-72)
    1125 oz-in Peak 72V/40A
    Constant Torque: 226 oz-in
    Peak Torque: 1125 oz-in
    No load Speed: 4000 R.P.M
    Terminal Voltage : 72 VDC
    Continuous Current: 7.8 A
    Peak Current: 40 A
    Weight : 4.25 Kg
    Skewed Rotor Design
    - See more at: NEMA34 Skewed Rear Shaft DC Servo (KL34-180-72), SKEWED ROTOR DESIGN | Automation Technology Inc
    Z axis servo - NEMA34 600oz/in Dual Shaft DC Servo Motor (KL34-150-90)
    600 oz-in Peak 90V/38A
    Peak Current: 38 A
    Terminal Voltage : 90 VDC
    - See more at: NEMA34 600oz/in Dual Shaft DC Servo Motor (KL34-150-90), SKEWED ROTOR DESIGN | Automation Technology Inc
    For more info on my router design here is the CNC Zone build link: http://www.cnczone.com/forums/cnc_wo...outebot-3.html
    Thanks!
    Allen
    Feb 2009
    6028
    Advanced motion controls.
    Dec 2012
    102
    I'll call Advanced motion controls and see what they recommend. I also had a guy suggest the Viper 200 DC Servo-motor Drive. Any other drives I should check out?
    24223
    What type of command signal do you intend?
    A-M-C are principally ±10vdc analogue, Viper are step/dir.
    Al.
    Albert E.
    Dec 2012
    102
    It would be step/dir. So I guess the Advanced Motion Controls drives are out. So is the Viper drive my best option?
    Aug 2006
    143
    I'm running the CNCdrive DG4s drives in my mill and have 3 of the earlier version Dugong drives on my router and couldn't be happier. I;m getting ready to buy 3 more DG4S drives for my other mill. I do mold and pattern work and have run both machines for hours and days at a time without any problems.
    I'm also using their UC-300 motion control card in the mill and it rocks.
    Derek
  1. Fanuc servo tuning software.
    By GPena in forum Fanuc
    Last Post: 03-16-2019, 02:14 AM
  2. Replies: 158
    Last Post: 12-08-2014, 05:41 PM
  3. Replies: 1
    Last Post: 04-25-2010, 04:34 PM
  4. Tuning a G340 servo drive
    By chas in forum Gecko Drives
    Last Post: 04-07-2005, 01:15 PM
  5. Anyone with experience tuning a Compax servo drive?
    By ESjaavik in forum Servo Motors / Drives
    Last Post: 08-14-2004, 12:33 AM
