Hey guys! I just signed up to this forum; I've been lurking around for quite some time and it has been an awesome resource for me! Let me tell you a little about my project. I have always wanted a CNC router for some of my prototype projects. I decided I was going to have a go at building one. I ordered some ballscrews, linear rails...
Nema 23 stepper motor 435oz,in,3.0A
Stepper motor driver DM542A, 24-50VDC
Power Supply 350Watts( 36VDC/9.7A)
Breakout Board DB25
... So then I got busy and the project sat for a few months... Then I was surfing craigslist and found a used 6040 for a deal! I picked it up from the acrylics shop. I was stupid and didn't have them run it for me. Lucky for them I guess! I brought it home and got everything setup. I was having issues with the stepper motors so I replaced them with the stepper motors I purchased for my original build. I was still having issues so I took a peek inside the BLUE control box to see what the problem was. I've read a lot of bad things on this blue box. This is what I found...
So I decided to replace everything with the components I purchased previously. Got that all wired in Sunday evening, and got movement out of the machine last night:banana: I was proud of myself! For being a Mechanic/CAD operator, I thought I did a good job so far! Anyways, I'm having some trouble understanding the motor tuning with mach3, I'm sure this has been covered 100's of times. But I'm not too sure what settings my drivers should be on. At first my steppers were turning VERY VERY SLOWLY with the 8128 steps per inch/65vel/12accel (that the manual told me to tune my motors too).
Okay, Okay, first.. my drivers:
Set to Peak 2.84A since my steppers are rated for 3A
Now the part I'm confused about, but now that I am thinking about it... I think I've figured it out! So my stepper motors are 1.8* that means 200 Steps per rev... Okay, nevermind, I just realized I'm still confused.. I set the steps to 8000 per rev. but I'm thinking now it should be 800 steps per rev. because I have 4 leads at 200 steps per rev? Here is a picture of my options..
Attachment 202008
Then for motor tuning, like I said, the manual instructed me to use: 8128 steps per inch/65vel/12accel
My ball screws have a 5mm pitch = .19685"
Which means to turn 1" I need 5.08 revolutions.
I was messing around with everything last night, trying different combinations... and got it going. Loaded up some G-code and...
http://s1209.photobucket.com/user/ni...13dc0.mp4.html
After that I turned off my controller and computer to make sure all the settings saved. Started it back up and everything was back to as SLOW as can be... even with the exact same settings. As I was jogging my X stepper, it started making noise (like is was hitting a hard limit) and wouldn't turn. I turned the controller off, the ball screw turned easily, no binding. Rebooted, gave it a quick jog again and then the motor completely died... Thankfully I have a spare motor. I'm kinda lost with why it would've done that. Did my settings fry the motor?
