I have a 4mm diameter 2 flute solid carbide endmill that I intend to cut MDF with. I'm up to the point where I need to determine feed rate and spindle rpm and was wondering if someone could kindly check my workings so to speak with what I've roughed out.
From this onsrud table (http://www.onsrud.com/files/pdf/2012...ools%20MDF.pdf)
Chip load of around 0.005 (for a 5/32 diameter bit - 4mm) from the table
And using the formula: feed rate IPM = RPM x cutting edges x chip load
So for 16,000 RPM and a 2 flute up cutter, that works out to 160 IPM or 2.67 IPS
Does 2.67 IPS sound about right?
I'm just worried I'll break the bit or ruin it with too much heat, kind of a newbie question I'm trying to get my head around.
