Hi Everyone,
I just picked up an 4020 and am getting a 1-1 Bus Error primarily at two access addresses after transporting it home. One is FFF7804E and the other is FFF03FCA. I was told that these point to any ECP related board. To narrow it down, I alternately took the CCOP2 and CCOP cards out of the fiber loop. This seemed to point to the CCOP2 board being faulty, as when I pulled it out of the loop, the machine booted up. Of course when I tried to do anything, it gave an error, usually with the same two addresses mentioned above. If I swapped the CCOP2 board back in, the machine failed to boot. So I bought a replacement card thinking it was the CCOP2, but the machine acts the same with the new card.
I then alternately pulled the ribbon cable connectors on the FOHT and FOPT cards, leaving one connected. The machine boots with the FOPT card attached, but not the FOHT, seemingly pointing to the FOHT card. I've ordered an FOHT card to swap in and try as it was cheap. Interestingly enough, if I unplug the blue I/O connector (the CN3 Y1) on the FOPT card while the ribbon cable is connected as it should be , then the machine will boot. Plug it back in and it won't. I get the same 1-1 CPU error every time, but sometimes it changes the address depending on what I put in and pull out. I can make it do an FFF02214, FFF022CB, FFF7822E unplugging various things, but most commonly, when everything is plugged in as it should be, an FFF7804E and an FFF03FCA. These two are the ones I'm really worried about.
I am downright confused here. I have all of the manuals, but none really help this issue. I did find a loose connector and a ripped wire going to the magazine drive board, but I fixed those and nothing changed. I WAS told that the machine had tool changer problems when I bought it, but that everything else worked fine...This, to me, would seem to support that it has something to do with the CCOP2/FOHT/FOPT cards or wiring.
Has anyone come across this issue before?
Now, where I really can't find any information or do any work whatsoever is in dipswitch settings for various components. I'm worried some may have moved in transport and I have no clue where they should actually be. Specifically, the switches on the new CCOP2 and old CCOP2 boards are different and both are different from some pictures of board I have seen online from the same era machine I have (1995). Is there any way to figure out what the numerous switch settings are supposed to be?
I apologize for the length of this message, but thank you very much for your time. I am very willing to compensate whoever "leads me to the cure", as well.
Best Regards
