586,119 active members*
3,646 visitors online*
    Nov 2012
    46
    how to use a G540 and KFlOp
    Hi all,
    New to CNC and the controls. In the collecting parts phase to CNC my mill. I have not bought Mach, looking at options, KFLOP sounds interesting.
    I already have a G540 with the parallel port for a PC.
    Can and if so, how does, Kflop wire into a G540?
    May 2006
    4045
    Hi johnyac,
    KFLOP works well with Gecko G540. KFLOP has similar output signals as a PC Parallel Port and can generate much faster pulses with much less jitter. But KFLOP's connectors have different pinouts. You will need to make a custom cable. Connect KFLOPs Step and Direction pins to your G540 Step and Direction Inputs. Configure KFLOP's Step/Dir generators for 3.3V LVTTL outputs (not open collector mode).
    Regards
    TK
    http://dynomotion.com
    Nov 2012
    46
    Thanks for the input Tom.
    Does anyone have a drawing or pin configuration showing how to wire a G540 to the KFLOP?
    May 2006
    4045
    Hi johnyac,
    You might read this old Thread by Fish
    Regards
    TK
  1. Replies: 1
    Last Post: 08-27-2018, 08:41 AM
  2. KFlop 4.3
    By John Coloccia in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-03-2013, 07:57 PM
  3. Kflop and pokeys together
    By gavztheouch in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-18-2012, 01:16 AM
  4. Kflop+kstep out of syn
    By ltran2000 in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-09-2012, 04:41 AM
  5. Kflop JP5 (new user).
    By JonS in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-08-2012, 08:44 PM
