586,106 active members*
3,140 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport series 1 R2C3 with TNC 145 control stopped running.
Results 1 to 6 of 6
    Apr 2006
    24
    I was running mi machine and loaded another part. when I pushed the cycle start button nothing happened.
    I could still use the hand wheel but the jog lever wouldn't work. So I shut it down completely. When I rebooted
    The machine It won't pass over the limit for home. Any help would be appreciated.
    Mark
    May 2013
    128
    Check the clamping , Hydraulic pressure and any interlock
    Apr 2006
    24
    No interlocks just a basic machine Thanks
    1121
    check the way oil
    If you have the manual use the check list for the EMO string
    xyz limits oil etc
    Apr 2006
    24
    Well that something to check will check tomarrow let you know Thanks
    Apr 2006
    24
    Gus you were spot on added way oil and started right up. thanks alot must have been an interlock as in the previous post thanks to all you been a big help.
  1. Getting Bridgeport Series II Interact 2/Heidenhain TNC 151 running
    By maxvdh in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2017, 09:25 AM
  2. Bridgeport Cnc R2C3 Parameters TNC 145 Heidenhain control
    By Trump in forum Bridgeport / Hardinge Mills
    Last Post: 07-07-2014, 09:12 PM
  3. Replies: 0
    Last Post: 08-30-2013, 01:25 PM
  4. series 1 r2c3 tnc 145 ref pass over not workig
    By R6YNO9 in forum Bridgeport / Hardinge Mills
    Last Post: 09-08-2011, 03:20 PM
  5. Bridgeport Series 1 R2C3 Problems
    By Vigilance in forum Bridgeport / Hardinge Mills
    Last Post: 12-29-2010, 12:21 AM
