586,071 active members*
3,931 visitors online*
Results 1 to 8 of 8
    Dec 2004
    411
    Add variable speed to router?
    Hi
    I'm thinking of buying a router through ebay (good price) but it doesn't have variable speed.
    Would it be practical to cut the cable and place a variable speed controller in line?
    I am wondering if it would affect torque; causing heating problems; only work with certain types of motors, etc, etc. Ignore warranty... I'll take the risk
    Andy
    Drat, imperfection has finally stopped working!!
    24221
    Need to know the type of motor? 3phase? Universal? etc.
    Al.
    Albert E.
    Dec 2004
    411
    Just a home handyman router by Ryobi (1120W, 240V, 25,000 RPM).
    Is that enough info?
    Andy
    24221
    That would be a Universal Motor, the most economical is the SCR/TRiac style. There are some cheaper ones from some of the surplus places, there is also an IC available, TDA1085c from OnSemi that runs off the incoming supply, the data sheet shows a circuit and board, but it has a tach feedback for speed control.
    I have one on my band saw, that has a simple digital tach ( about 25p/rev), works well.
    Al.
    Albert E.
    Dec 2004
    411
    Wonderful.... thanks...
    auction closes in 23 minutes.... I'll let you know when I get back from hardware store if I got it.
    Andy
    Mar 2006
    4
    If your talking about something like this then you need to know that it will not work with soft start routers.
    Aug 2004
    2849
    Well if the router is a soft-start...then it already most likely has variable speed.....last time I looked all router were universal type motors...
    Dec 2004
    411
    :frown: Missed out by $6
    Thanks for the input guys all the same.
    Ciao
    Andy
