587,072 active members*
3,062 visitors online*
Results 1 to 12 of 12
    Nov 2005
    Wabeco Speed Control
    I am trying to get the spindle of my Wabeco F1210 mill under Mach3 control. At present the speed is controlled by a 220K pot into the Wabeco controller card which uses a TDA1085C motor control IC. I think the motor is a universal AC/DC type ran on AC like a washing machine motor.
    Does anyone do a controller for such a setup that will take a PWM, or even a 1-10V input?
    Can I run this motor as a DC motor?
    Thanks!
    24223
    You can control the TDA1085 with a 0-10v signal between 8 (common) and pin 5, one thing to watch for when hooking into the TDA1085 is that the circuit is usually not isolated from the incoming AC supply, if controlling with an analogue signal of 0 to 10v you should use a variable resistance opto isolator, this type is different from the usual opto in that the output offers a resistance that is dependent on the voltage in.
    The motor is a Universal type so it can be run in the DC mode, which is what it is running with the TDA1085.
    Al.
    Albert E.
    Nov 2005
    Thx for info, Al. Actually, before your answer I was convinced the motor was running AC, as live and neutral from the mains switch go right into the motor harness, presumably to the stator windings.
    I've even had our washing machine apart to understand what's going on (took some explaining!) - and that too has 6 wires going into the harness. 2 for speed sensor, and a pair each for stator and commutator windings(?)
    Is it normal for a universal motor to have permanently energised stator windings, and just vary the power to the commutator? All the texts talk of the stator and commutator windings being in series.
    24223
    If the field windings are being controlled separately it really is no longer a series motor, If the field and armature are being controlled separately then it begins to resemble a shunt controlled motor, if the field is fed from the AC supply direct then the armature would have to be Triac fed as the armature and field would have to be kept in phase. I have never heard of that set up for a universal motor before.
    Al.
    Albert E.
    Aug 2011
    5
    Re: Wabeco Speed Control
    I know that is too old topic but even so I ask you if somebody solved it? Problem is that voltage on 220K pot is from 15,6 for min. speed to 8,4 V for max. speed. How could be possible to solve this if I can controll speed by 0-10 V? I send as attachment the schema of Wabeco speed controller.
    Thank you for your response.
    Attachment 272208
    Nov 2007
    13
    As a matter of fact Wabeco sells a speed control PCB for the 1.4Kw motor.
    At MDA Precision we are considering to replace that motor with a far superior 1.4Kw servo motor.
    M. Menig
    Aug 2011
    5
    Quote Originally Posted by MDA Precision View Post
    M. Menig
    Quote Originally Posted by teqa View Post
    Attachment 272208
    Where can I find the component list from the speed control PCB for the 1.4Kw motor.
    I like to make a new one.
    I try to find a solution for the 0 to 10 v speed.
    Aug 2011
    5
    Quote Originally Posted by Ttvdoorn View Post
    this schema was aranged by me from original PCB Wabeco speed control for 1,4 kW motor. This is picture which include components.
Name:	speed control_Wabeco 1.4 kW.jpg
    Aug 2011
    5
    Hi Ttvdoorn,
    I have a PCB for 0 - 10 V speed control for Wabeco 1,4 kW DC motor too.
    Do have a drawing from the speed control printed circuit ass well?
    Aug 2011
    5
    I bought it directly from Wabeco as PCB, I have one for sale.
  1. 180V DC Motor Speed control Neco speed controller card - PLEASE HELP
    By gridevolver in forum CNC Machine Related Electronics
    Last Post: 01-22-2019, 06:44 PM
  2. Damp? Sieg X1 speed control and stepper control.
    By Memran in forum CNC Machine Related Electronics
    Last Post: 02-05-2014, 10:16 PM
  3. Cutting speed locked to Z torch height control speed
    By Beefy in forum Mach Plasma / Laser
    Last Post: 02-15-2010, 12:14 AM
  4. MACH3 to control spindle speed of Wabeco F1210E
    By pdyer in forum Benchtop Machines
    Last Post: 07-23-2008, 06:34 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
