I am running XP pro on a gateway notebook computer which is running mach3 and mach3 is controlling my 3D printer with 4 stepper motors
The motors and 3D printer all work fine
I have the notebook stripped down to bare bones and have not experienced any pulsing problems so far.
What I want to do now is use M7 and M9 to turn on and off a relay board that turns off 12 volts to the hot end temp control board.
So basically, a relay board will turn off the 12 volts going to the hot end after a job finishes and shut down the extruder
I have a relay board that works fine on my CNC machine desktop computer running xp pro.
The relay board uses a mosfet to control the relay coil
All it needs is a high/low voltage to trigger the mosfet/relay coil.
On my desktop cnc machine I can read a steady 5 volts on the parallel port output pin when I enter M7 in mach3
On the notebook I get a wavering voltage figure that is not steady at all
It wavers between 2.2 volts and back down, then up, and down, etc.
This is not enough to trigger the mosfet/relay coil
It's a plug in pcmia parallel port card and it works fine for all 4 motors, but there does not seem to be enough steady DC voltage to trigger the mosfet/relay coil
I am scratching my head as to why the pcmia card is good enough to operate all the steppers but I can't get a decent hi-lo voltage on an output pin
Output #2 LED does light up in Mach3 when I enter M7 and it goes out when I enter M9
Output #2 is assigned to pin #1 on my breakout board but I tried pin 14 also with the same results.
So how can a pcmia parallel port card work fine in Mach3 to run 4 motors but not be able to supply a steady DC voltage on an output pin?
thanks for any help
