Hello,
I have a CNC lathe Hardinge conquest cs-42, serial cs-806, with Fanuc control OTC, and i am needing the machine parameters. Can you help me with this?
Hello,
Contact Hardinge support and they will help you. They are pretty good to work with.
I communicate with them, but the parameters that they sent me are of a lathe with Fanuc OTB control, and this has difference with the Fanuc OTC control. It seems that Hardinge has no further information on this machine.
Just a heads up there is not much difference in the 900's between machines we have an OT and O-T and the only diff is 917 is activated on one and not the other. I do have them if you still need them.
