586,072 active members*
4,369 visitors online*
Results 1 to 12 of 12
    Oct 2013
    64
    Repeatability issue
    On our ST40-L, we frequently see tools cutting about 1/8" differently than programmed (possibly 4x TNR). Pressing reset, and restarting the process results in an accurate cut. Haas technicians are working with us on this issue, but lead us to believe this has never occurred before. If it is a programming issue involving compensation, it should still cut exactly the same each time, yet it doesn't. Has any one run into this situation before?
    Mar 2010
    1852
    You say "Pressing reset, and restarting the process," but does that mean you are restarting the program or restarting the machine?
    If you mean that you are restarting the machine, I would look for an encoder problem/error.
    If you are just restarting the program, then I would look for a programming error, like accumulating G91 moves.
    What is your level of experience with this machine and how are you programming?
    Good Luck----Mike
    Oct 2013
    57
    I've had pre-load issues causing excessive backlash on some Bridgeport VMC's , Once the machine changed direction the position was not accurate. You may want to confirm your ball screws condition ... just a thought
    Feb 2009
    6028
    I would write a simple repeatability program to a test indicator and see what's going on. Then do the same test but index the turret in the test. 1/8" is a lot, not something like backlash. When you re start, are you also re zero returning the machine?
    Jul 2009
    80
    Sir
    I've seen same issue on some ST machines, double check parameters for X axis.
    There should be a thermal compensation value that isn't right.
    Ask the Haas guys to verify this for you against original parameter list.
    You'll find it there.
    It is not related to programming or mechanical problem.
    Robby
    Oct 2013
    64
    The machine was new this spring. Our prior lathe was "Fanuc compatible", so the old programs just need minor editing to run. It's not an issue of not cutting to the right diameter, but literally not cutting to the programmed diameter. We don't use G91, but Mike's thoughts about something accumulating seem possible since we get accurate results simply by re-running the process without any changes. This process for example sometimes does not finish the bore at 11.1", and the display shows that it is about 1/8" off. I see that the X value is the same when G41 is activated, but if that is the cause, would that make it run correctly most of the time, but not every time?
    N06 (FINISH BORE)
    T1010 M08
    G00 X21.2 Z0.8075
    Z0.1
    G96 S1000 M03
    G01 G41 X21.2 Z0. F0.006
    X21.0625
    G02 X13.128 Z-1.2492 I1.1688 K-10.636
    G02 X11.1 Z-2.9599 I0.936 K-1.7107
    G01 Z-6.5
    X11.
    G00 G40 Z.1
    X23.7Z15.
    M05
    T1000M09
    M01
    Mar 2010
    1852
    I assume you are running a main and a sub program since you are talking about multiple parts, but you are only listing one section. Post it all and we will be able to see where it accumulates maybe.
    Mike
    Oct 2013
    64
    Here is the program from the lathe. The Back Face process was programmed to rapid in .100" away on X, but crashed into the part because it wasn't at the programmed diameter, so the operator changed that. The Rough Bore process does a tracer pass at the end, and stops at X 10.3", not 10.2" as programmed. Both the Finish OD, and Finish Bore sometimes leave about 1/8" on the X.
    O00013 (CMS0013 FRONT COVER)
    G54
    G40
    M41
    G50 S300
    T202
    G00 X22.4 Z0.5
    T202 M08 (ROUGH FACE)
    Z0.41
    G96 S800 M03
    G72 P10 Q20 W0.01 D0.06 F0.014
    N10 G00 Z0.
    G01 X18.75
    N20 Z0.1
    G00 X23.
    M05
    T200 M09
    M01
    N1 (ROUGH OD)
    G54
    T202 M08
    G00 X23.8 Z0.1
    G96 S800 M03
    G71 P30 Q40 D0.1 F0.014 U0.03 W0.01
    N30 G00 X21.0375
    G01 G42 Z0
    X21.0625 Z-0.0125
    Z-0.7473
    X21.119
    Z-1.1535
    X23.225
    X23.25 Z-1.166
    Z-2.45
    N40 X23.9
    G00 G40 Z0.1
    X24. Z15.
    M05
    T200 M09
    M01
    N2 (BACK FACE)
    G54
    T606 M08
    G00 X23.9 Z0.1
    Z-2.4
    G96 S800 M04
    G72 P50 Q60 D0.06 F0.014 W-0.01
    N50 G01 X23.9 Z-1.7688 G42
    X23.28
    X23.255 Z-1.7813
    X19.8
    N60 Z-1.88
    G00 X23.9
    G40 Z0.1
    X23.7 Z15.
    M05
    T600 M09
    M01
    N3 (ROUGH BORE)
    G54
    T1010 M08
    G00 X10.3 Z0.1
    G96 S800 M03
    G71 P70 Q80 D0.1 F0.014 U-0.03 W0.01
    N70 G00 X21.2
    G01 G41 Z0.
    X21.0625
    G01 Z-6.85
    N80 X10.2
    G00 G40 Z0.1
    G00 X23. Z15.
    M05
    T1000 M09
    M01
    N4 (FINISH OD)
    T202 M08
    G00 X21.0625 Z0.1
    G96 S1000 M03
    G00 X21.0375
    G01 G42 Z0 F0.006
    X21.0625 Z-0.0125
    Z-0.7473
    X21.119
    Z-1.1535
    X23.225
    X23.25 Z-1.166
    Z-1.85
    X23.35
    G00 G40 Z0.1
    X23.7 Z15.
    M05
    T200 M09
    M01
    N5 (FINISH BACK FACE)
    T606 M08
    G00 X23.35 Z-1.88
    G96 S1000 M04
    G00 Z-1.7688
    G01 G42 X23.25 F0.006
    X23.225 Z-1.7813
    X19.8
    Z-1.88
    G00 G40 X23.35
    X23.7 Z15.
    M05
    T600 M09
    M01
    N6 (FINISH BORE)
    T1010 M08
    G00 X21.2 Z0.8075
    Z0.1
    G96 S1000 M03
    X21.0625
    G01 X11.101 Z-6.85
    X11.
    G00 G40 Z0.1
    G00 X23.6 Z15.
    M05
    T1000 M09
    M01
    N7 (RELIEF GROOVE)
    T1212 M08
    G00 X21.22 Z-1.1535
    G96 S600 M04
    G01 X21.12 F0.003
    X21.0625
    X21.22
    G00 Z-1.0593
    G01 X21.12
    X21.0625
    Z-1.1535
    X21.22
    G00 Z0.1
    G00 X23.7 Z15.
    M05
    T1200 M09
    M30
    Feb 2010
    1184
    Quote Originally Posted by underthetire View Post
    Definitely do something like this. Make something simple with very few variables to help track down the issue.
    If the machine runs good with a simple/basic program, then start comparing what is different and how the machine is reacting to the differences.
    If it does not run good with a simple/basic program then check your parameters as was mentioned already.
    Good luck and keep us posted!
    Oct 2013
    64
    The machine does not always run good with a simple program. A Haas Technician is going to update the software to the latest version tomorrow. I will mention the parameters to him when he is here. If it is a parameter set wrong, I would thick it would perform wrong every time start is pressed, but I've assumed wrong before. Thanks for the input, I'll keep you posted.
    Oct 2013
    64
    This morning, the Haas Technician loaded the software to fix the cutter comp issue. Thus far, all is well.
    Oct 2013
    64
    Re: Repeatability issue
    It's been about 6 months and our ST-40L is still running well after the software upgrade. Although the problem was a result of their Software Project #46614, which caused it to sometimes use an incorrect tool offset, they only corrected it, and did not address the $10,000+ of scrap and several late deliveries that resulted due to their software glitch.
  1. Tormach repeatability
    By mdred68 in forum Tormach Personal CNC Mill
    Last Post: 01-15-2011, 07:10 AM
  2. Accuracy, Repeatability
    By bohica in forum Charter Oak Automation Support Forum
    Last Post: 11-15-2009, 10:01 PM
  3. Issue with Repeatability and accuracy
    By mahmoudtsh in forum DIY CNC Router Table Machines
    Last Post: 01-27-2009, 02:46 AM
  4. Z axis repeatability
    By JERRIMY in forum Stepper Motors / Drives
    Last Post: 01-23-2007, 06:16 PM
  5. VF-3SS Repeatability Issue
    By Kazsaw in forum Haas Mills
    Last Post: 10-02-2006, 10:05 PM
