586,076 active members*
3,750 visitors online*
IndustryArena Forum > CAM Software > CamBam > cambam lead in betwean passes
    Feb 2010
    71
    hello
    can i add lead in moves in pocketing operation when cutter going in next pass but on the same level.
    Jan 2010
    18
    hello,
    yes you can!
    If the Max. Crossover distance value is smaller then the Step Over and you use a tangent lead in, you get a lead in to every path on the same level. But you get also a retract to clearence plane for every path.
    ralf
    Attached Thumbnails Attached Thumbnails Bildschirmfoto 2013-10-07 um 17.34.50.png
  1. Finishing Passes
    By laserpilot in forum Vectric
    Last Post: 07-29-2012, 02:13 AM
  2. G76 Number of Passes
    By eliot15 in forum G-Code Programing
    Last Post: 04-09-2011, 12:51 AM
  3. finishing passes of G76
    By sinha_nsit in forum Fanuc
    Last Post: 12-23-2010, 08:23 PM
  4. Roughing Passes Exceeding Finishing Passes
    By phoodieman in forum Mastercam
    Last Post: 03-01-2009, 01:21 PM
  5. Can't get multiple passes in v3.0
    By Vogavt in forum Uncategorised CAM Discussion
    Last Post: 01-26-2008, 10:57 PM
