Originally Posted by
glbreil
I started up my mill yesterday and when I hit cycle start button to home the machine it said "Z axis encoder bad connection". X and Y axis both jog okay.
Of course the machine would not home so I went to the PID screen and the Z axis encoder says 0. The axis will not move and if I rotate the motor manually it does not change the encoder counts, however I switched encoder cables around to where it was on the X axis connection on the CPU and then when I move the motor manually it does count so the encoder and cable are good.
By my testing that means that the Z axis port on the CPU is not working. The CPU has both a W axis and a 5th Axis but if I just move the cable over to the W axis the buttons for the 4th Axis do not move the motor, but if I move it manually the encoder does count. Is there a way to use one of those other ports or does the CPU have to be replaced, or is there something else that might cause this.
Thanks Gary Breiling
