586,847 active members*
2,355 visitors online*
Page 1 of 2 12
Results 1 to 20 of 36
    May 2009
    1333
    VFD / Spindle Selection
    For my next spindle selection I would like to get a VFD along with an air cooled or water cooled spindle but the limitation is my available AC source which is 120VAC /15A. It is not possible to get a new line from my panel unless I start braking walls and I dont want this hassle since the panel is located far away.
    It looks like that the Hitachi WJ200-004MF is the only one available for my AC source and its rated for 1/2HP spindles.
    But the spindles available as far as I can see are 0.4HP or 1HP. The 0.4HP is quite small but I wonder is it possible to drive the 1HP spindle with a VFD rated for 1/2HP?
    What would happen? the spindle would not turn at all or it will run at reduced rate?
    Nicolas
    Dec 2004
    783
    Delta makes a 1 horsepower 120 volt inverter http://ugracnc.com/CNC-SPINDLES/Delt...75kW-110V.html
    Sent from tapatalk
    May 2009
    1333
    Good to know but noticed the Input current is 16A, will have to check it out to see how important it is
    Thanks for the help
    Nicolas
    Oct 2008
    2100
    Drives warehouse -http://driveswarehouse.com/p-2602-wj200-007mf.aspx
    Bob La Londe
    http://www.YumaBassMan.com
    Dec 2004
    783
    Quote Originally Posted by kolias View Post
    Thanks for the help
    16 amps when run at full load, which will very rarely, if ever happen for any length of time. A standard 15 amp circuit will do fine.
    Sent from tapatalk
    Dec 2004
    783
    Quote Originally Posted by Bob La Londe View Post
    Looks like a good option too.
    Sent from tapatalk
    May 2009
    1333
    Looks like there are a few options available
    Thank you
    Nicolas
    May 2009
    1333
    Still searching for options but right now I'm considering the UGRAcnc GMT Air Cooled Spindle 0.8kw along with the Delta VFD007M11A VFD, 0.75kw which Delta says is for 1 Phase, 115VAC, 16A, 12AWG wiring.
    Since the wiring at my wall outlet is 14AWG and I don’t want to take any chances overheating the wires inside the wall, I was thinking to install a breaker or fuse inside a sub panel which will be located on the cnc main control panel between the wall outlet and the VFD. This breaker will trip if I exceed 15A.
    Perhaps there are other parameters which I overlook and the above may not be a good idea?
    Nicolas
    Oct 2008
    2100
    If you only have 14 ga wiring the main breaker should already only be a 15 amp. Adding a breaker directly on your equipment won't hurt anything though.
    Bob La Londe
    Dec 2004
    783
    How inefficient is the inverter if it calls for 2.4 times the input over the max output? You would think the heatsink and fan would have to be huge to waste a horsepower to make a horsepower.
    How long is the run of 14 gauge from the outlet to the panel? Is it a straight run or is it daisy chained with other outlets? Anything else on the circuit?
    The recommendations might err on the safe side to account for voltage drop, which is understandable. I still doubt that the spindle will get maxed out for extended periods of time though, it's not an air compressor, the load varies big time during use.
    Sent from tapatalk
    May 2009
    1333
    Thanks Dylwad, had to get some info before I reply
    Don’t know about efficiency on the inverter but got some info on this link
    CNC With Vacuum Table Photos by kolias | Photobucket
    The VFD model I consider is the VFD007M11A
    The outlet which I will use to connect the VFD is about 40 feet from the panel. The 15A breaker which controls this circuit has 2 wall plugs in the garage (one for the VFD and the other in the opposite wall which is never used), one wall plug by the ceiling where the central vacuum is connected (will not use this when the VFD is ON), 2 garage door openers (again will not use when the VFD is ON) + 4 wall plugs in a bedroom on the top floor (nothing connected on them). Total wiring run of this circuit is estimated at about 80 feet.
    I don’t know very much about electrical except basic wiring and so I want to play safe and that is why I was thinking to put another fuse (breaker) from the wall outlet to the VFD
    If you want me to send you the link of the PDF document of the VFD, let me know. It is on the vendors web site I plan to buy from (ugracnc)
    Nicolas
    Oct 2008
    2100
    The 16 amps is probably at peak stall. It only takes about 7 amps at 120V to produce 1hp (750 watts apx). Figure if you add on a good safety factor, and never stall your motor... LOL.
    Bob La Londe
    Dec 2004
    783
    I was thinking about starting amps in non cnc spindle applications too (think escalator), but not sure how the vfd handles that. Remember cnc router spindles probably make up a small percentage of vfd usage in the real world, and are probably one of the lighter duty uses.
    My hitachi inverter shuts down and throws an error code if the load gets too high (spin up time too short), or if you try to stop it too fast without a braking resistor.
    Sent from tapatalk
    May 2009
    1333
    That sounds very good Bob, thanks
    When you get some time and if it's easy, I would like to learn how you figure out the 7 amps
    Nicolas
    Dec 2004
    783
    1 horsepower is approx 745 watts.
    Amps X Volts = Watts
    745/120=6.2 amps
    Sent from tapatalk
    Oct 2008
    2100
    Quote Originally Posted by Dylwad View Post
    745/120=6.2 amps
    Sent from tapatalk
    Cut me some slack. I ballparked it. But yes that is correct. I also throw in a little for inefficiency,
    - - - Updated - - -
    745/120=6.2 amps
    Sent from tapatalk
    Bob La Londe
    Dec 2004
    783
    Haha, I usually say 740 watts but googled it to be sure
    Sent from tapatalk
    May 2009
    1333
    Thank you both, very interesting
    Nicolas
    Oct 2008
    2100
    I usually use 800 because its hard to find a complete high speed 3ph spindle rated at 750. 750 is what you see a lot of folks using for their base for 1HP.
    - - - Updated - - -
    Bob La Londe
    Jan 2012
    394
    Why break apart the wall?
    You should just be able to tap into the existing panel and add a new external panel and just run the new line on the outside of the wall through some conduit to protect it.
    The only problem you would run into is if you wanted more amperage than what your current line to the pole will produce. Then it becomes expensive. In my case, I have to change out the entire existing panel, upgrade the meter outside, upgrade the line to the transformer on the pole, and, sadly, I have to have the electric company upgrade the transformer because there's just enough in there to supply the houses in my neighborhood. The new transformer i don't have to pay for, but everything else I do.
    Anyway, from what I've been reading, the Hitachi inverter is superior to the chinese ones you buy off eBay. Myself, I plan on going with a 10hp Hitachi VFD and run a 4.5KW spindle at 220volt. Because the spindle runs off of 3-phase, I have to double my VFD HP output to supply a single phase spindle.
    From my understanding, you can run the VFD at less power to run a smaller spindle. It's all in the programming of the VFD. If you go with a 1hp spindle, but only a 1/2hp VFD, i could see some problems, one of which, the motor may stall out when cutting because the power it is craving will not be there. You should be okay with the .4hp spindle on that 1/2hp VFD though.
Page 1 of 2 12
  1. cnc spindle motor selection
    By sharpen047 in forum DIY CNC Router Table Machines
    Last Post: 02-02-2013, 08:09 PM
  2. Spindle selection
    By sergizmo in forum Benchtop Machines
    Last Post: 07-25-2008, 07:55 AM
  3. VFD Selection for a Spindle
    By scubasteve_911 in forum CNC Machine Related Electronics
    Last Post: 08-14-2007, 08:47 PM
  4. spindle selection
    By Art Ransom in forum Uncategorised MetalWorking Machines
    Last Post: 07-04-2007, 05:50 AM
  5. Spindle Motor Selection
    By CRS in forum DIY CNC Router Table Machines
    Last Post: 01-12-2005, 03:02 AM
