586,100 active members*
2,906 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Anyone farmiliar with Heidenhain - Droop and Rein mill?
    Jan 2008
    27
    got error message 145 - Drives not enabled
    could not find in error list
    any idea what the problem might be?
    Jul 2013
    24
    Quote Originally Posted by chippah View Post
    If you could not find the error message in the error list, it may be that it was a customized error based from the original machine manufacturer. The best thing you can do is contact the original machine manufacturer and find out if there were custom faults built in.
    If it is not a custom error message, I would need to know the controllers and drives model numbers along with the program and machine you are using, but since you have looked through the error list, contacting the original machine manufacturer will probably be the best way to go.
    If you ever have more issues with your drives, check out the Learning Center.
    Jade
    Jan 2008
    27
    Re: Anyone farmiliar with Heidenhain - Droop and Rein mill?
    thanks Jade
    got a manufacture even though they are out of buss
    they got it thanks
  1. Durcon engineered stone/epoxy rein
    By copperhead4321 in forum Epoxy Granite
    Last Post: 06-15-2011, 03:26 PM
  2. anyone here really farmiliar with the tosnuc 888 controler!!!
    By agentr31 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-12-2011, 06:42 AM
  3. Cool Concept Car Machining (Droop & Rein)
    By Dead_Reckoning in forum MetalWork Discussion
    Last Post: 11-08-2009, 05:52 PM
  4. Heidenhain Mill Plus IT V500
    By Tnist in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-27-2009, 03:10 PM
  5. farmiliar with US Trademark TESS website?
    By mc-motorsports in forum Community Club House
    Last Post: 05-29-2009, 04:02 PM
