586,094 active members*
4,140 visitors online*
    Apr 2006
    24
    Got trash. need info
    I im really a noob at this, but i like a challenge
    I want to make a mill and later a FoamCutter. (Im a RC-plane builder/crasher)
    Well ive been looking around for about 6month now and i can't figure this out.
    edited the below link to make direct hit.
    I got 4 LB1845 http://service.semic.sanyo.co.jp/semi/ds_e/EN5505B.pdf that i got from a couple of inkjets.
    I really would like to use these to drive the 4 motors that came with them.
    Those steppers are 4 leads Mitsumis that i found out would be unipolar using the case for 5th lead.
    2 are Mitsumi M42SP-5
    (http://www.mitsumi.co.jp/Catalog/com.../5/text01e.pdf)
    and 2 are Mitsumi M42sp-7
    (http://www.mitsumi.co.jp/Catalog/com.../7/text01e.pdf)
    Same specs but diferent measurements.
    Well now for the part i dont understand.. THE REST. Does anyone have any schematics for using these kind of drivers?
    Maybe just explainging the leggs on the LB1845 would help me too. i see no dir-pin etc.
    please someone help and please excuse my english. Im a swede
    Best regards/Methuso
    for direct kontact: [email protected]
    :cheers:
    Apr 2006
    402
    I looked at the block diagram and there is no counter in it, so no puls/direction. You also have to define the PWM frequency. You can approach this problem in three way's:
    1) with a 4510 (presettable up/down counter), make a table which logic combination should activate which coil, and feed this through a Eprom or hard wired logic, which contains the steps.
    2) Make it in programmable logic, it probably will fit in a GAL. It is a little harder to master, it is the same as above, but in 1 package.
    3) program it in an TinyAVR. Along the way you learn to program the new cockroach of microprocessors, also 1 package, but with active Internet support. The crazy thing is that these processors cost (for me) Euro 1.37, which for me would exclude choice 1 and 2, because they are more expensive.
    Carel
    Apr 2006
    24
    ok thanks. ill look into it this weekend
    Im getting help from a friend that might jus now what You are talking about
    /Methuso
