586,108 active members*
3,100 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Rotary Toolpath for carmen - How to avoid tool collision with workpiece?
    Oct 2011
    23
    I recently started to tinker with Mastercam in a larger Workshop and tried to simulate the Rotary toolpath for carmen.
    The problem is that that at some point, when trying to machine the legs, the toolpath cuts away parts from the opposite leg.
    And on the last 2-3 steps through the whole leg.
    Here is a screenshot of a quick simulation (very rough steps)
    Attachment 204324
    Is there a way to avoid this?
    I could use a normal indexed finish pass but this would be kinda boring I think.
    I guess it was mastercam X5
    Thanks!
    Max
    Oct 2011
    23
    Really nobody an idea?
    I would machine the lower part with a normal indexed finish but the problem is that when I try to select just the upper part of the body for 4axis rotary, there is no clear line when it end because of the scattered arrangment of the surfaces and the machine seems to try to mill the inside of the body at the unclear border.
    There is also no containment option, otherwiese I would limit the area with a containtment.
    This really frustrates me because I guess there is a fairly logical way to solve it.
    I hope anybody can help me though.
    Thanks!
    Feb 2013
    4
    I would take a look at your surface normals in those sections.
    If one is reversed it will try and drive the tool to the other side of the surface.
    I have seen this before with 4th axis tool paths.
    HTH Ken,
  1. collision pair:'tool, stock'
    By wmbeau in forum BobCad-Cam
    Last Post: 10-22-2012, 11:27 PM
  2. Replies: 2
    Last Post: 04-03-2012, 08:59 AM
  3. Tool collision but not really?
    By Starleper1 in forum Mastercam
    Last Post: 12-18-2011, 09:38 PM
  4. ROTARY TOOLPATH
    By dpark1 in forum Mastercam
    Last Post: 04-09-2008, 09:15 PM
  5. tool holder collision check
    By javed08 in forum PTC Pro/Manufacture
    Last Post: 10-04-2007, 04:42 PM
