586,403 active members*
2,875 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 16i-m Lasercut X axis faulty - NO alarms... =[
    Oct 2013
    4
    We run a fanuc 16i-m lasercut for making steel rule dies. We have recently run into a problem where the x axis doesn't burn properly. A test of 4 parallel lines comes out uneven on the x axis. the y axis is fine. there are no alarms. none on the display or on the servo amps. Has anyone run into this problem?
    Oct 2013
    4
    Nobody? Any ideas?
    Oct 2013
    4
    could a bad encoder cause such a problem?
    Nov 2011
    13
    Hi jesrd
    more likely its a ball screw or mechincal issue on the Yaxis
    check backlash on both x & Y axis
    The Black Watch
    Oct 2013
    4
    i have a late reply but it ended up being the pin that secures the motor gear that connects to the belt on the x axis. it was indeed mech thank you.
  1. Mazak AJV 4th and 5th Axis drive faulty
    By sonu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-01-2013, 07:01 AM
  2. Fanuc O-T Alarms
    By deltaguy in forum Fanuc
    Last Post: 06-17-2012, 01:45 AM
  3. Help With Alarms Fanuc 10
    By pfmn95492 in forum Fanuc
    Last Post: 05-07-2012, 09:59 PM
  4. Fanuc OP-B Alarms!
    By MagnaFX in forum Fanuc
    Last Post: 04-25-2012, 07:30 PM
  5. Fanuc 400 alarms and other
    By alphatad in forum Fanuc
    Last Post: 02-04-2008, 03:32 PM
