Had a machine moved here recently that was working and when I powered up the NC the fuse(F5 according to the diagram on it) in the X axis VCU(A06B-6045) blew immediately. I checked the larger fuses which appear to be fine, I disconnected the power from the motor and the fuse doesn't blow.
When it comes to checking the power cable on the motor and the motor its self I'm not really sure what exactly to look for, I have a multi meter just not sure what to check and what it should read.
