586,094 active members*
3,912 visitors online*
Results 1 to 7 of 7
    Aug 2010
    156
    citizen stops on M7
    not everytime but 3-4 times a day my machine freezes in the program on a "M7" command (open collet)
    citizen M5 16 with a cav-is bar feeder.
    Feb 2008
    267
    Quote Originally Posted by hitachibos View Post
    What is your RPM just prior to opening the collet?
    It may be that it's right on the edge of what is allowed and needs to be lowered to open the collet.
    Does this machine have servo motor for collet open?
    Do you get any alarms or messages in the message window?
    Control the process, not the product!
    Machining is more science than art, master the science and the artistry will be evident.
    Aug 2010
    156
    RPM = 300
    Servo motor & ball screw for collet open have been replaced.
    voltages are 211v 24v 5v all good
    Bar feed torque is set properly
    it started happening once everyother day now every 20 mins
    Feb 2008
    267
    Any alarms?
    Have you tried it with the spindle off?
    You say that you replaced the motor and ball screw, was that because of this issue?
    Oct 2008
    108
    This sounds to me like you may be having a problem with the cable. The control itself issues a command and then waits for the component to respond to it saying that the task has been completed. If the controller issues the M7, but does not get a response from the servo, it does not know its open. I would try a couple of M7s with g4 between them, eg:
    M7
    G4U.5
    M7
    G4U.5
    M7
    I have made a habit out of doing this is all my programs. A little oil in the cable can cause a lot of head scratching.
    www.atmswiss.com
    Oct 2013
    8
    We had something similar happen with one of our B12's. It turned out to be a dodgy encoder on the collet motor (these are the red capped things on the drive motors), we would have to re zero all the axis before we could start the machine again. It would work for about half a day then stop, just like your on collett open / close.
    Once we changed it over all was ok and still running fine.
    Aug 2010
    156
    Thank you all fopr help it turned out to be a bad MACRO MEMMORY CASSETT HR415 replaced it reinstalled Sram and everything has been good since.
    Thanks again
  1. NEWBIE to Citizen - G32 thread whirling on Citizen L520???
    By jmonty in forum CNC Swiss Screw Machines
    Last Post: 09-07-2013, 06:50 PM
  2. X stops moving.
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 12-16-2010, 06:29 PM
  3. Machine stops Help!
    By njitnjau in forum K2CNC
    Last Post: 11-17-2008, 07:20 PM
  4. Replies: 0
    Last Post: 06-30-2007, 10:13 PM
  5. What if the spindle stops?
    By WoodSnarfer in forum CNC Machine Related Electronics
    Last Post: 02-19-2007, 04:00 PM
