586,069 active members*
3,498 visitors online*
Results 1 to 11 of 11
    Nov 2006
    473
    Coaxial indicator
    Hi all
    I am trying to learn to use my Hurco md3 with the ultramax controller.
    I am trying to find the center of a 3 inch hole using a coax. The problem is in manual the lowest rpm is 490.
    How do you find the center of a hole.
    Steve
    Sent from my iPhone using Tapatalk - now Free
    Jun 2008
    71
    I'm not sure about the MD3 but on the VMX42 and VM2's we have they can be adjusted down to 1RPM I use either the Blake CoAxial or a .0005 indicator on a Indicol holder.
    Mar 2013
    156
    pgf545
    I can program the speed I need when the machine is in Automatic, The tool can be set low enough to use the coax. The problem is when I switch to manual so that I can move the mill in X,Y, to center the hole. It reverts back to 490 as the minimum RPM . Way to fast for a coax. I was told that when in manual, the spindle gearbox switches to high speed. I don't know if this is true.
    There has to be a way, or at least a way to find center of a hole.
    steve
    Jun 2008
    71
    I'm not familiar with that particular machine, we did have some older Hawks and KM3P machines but you could switch them between low and hi manually. Maybe someone else has experience with this machine. Can you rotate the spindle by hand and use an indicator?
    Bernie
    Jun 2008
    71
    Here is a picture of my indicator setup if it helps
    Attachment 204820
    Also I forgot to ask but what happens when you try to change the speed in the manual setup screen? I took a couple of picture of mine this morning.
    Attachment 204822
    Attachment 204824
    You can see on this one that when I tried to program a low speed it created an error.
    Attachment 204826
    Bernie
    Mar 2013
    156
    PGF545-
    I wish my controller was that new! Mine is a dual monitor type.
    So I have looked and looked and cant find a way to either use a coax in manual, or touch off on three points.
    How does everyone find the center of a hole. There has to be a way!!!
    Steve
    Feb 2012
    67
    Indicol Holder and an indicator.
    Tom
    Jun 2013
    43
    I use an edge finder touch off one side, store pos, jog to opposite side and divide the difference. There's x centered. Then do the same with y.
    Jun 2013
    43
    Like this: https://www.youtube.com/watch?v=G8qv...e_gdata_player
    Can use this technique on an inside hole or around a perimeter.
    Nov 2006
    473
    Meaty chips-
    Worked. Great. I don't know why I was making it so hard.
    Thanks for the tip
    Steve
    Jun 2013
    43
    Quote Originally Posted by scrambled View Post
    Meaty chips-
    Thanks for the tip
    Steve
    Glad to help man. Sometimes the simplest solution to a problem is the best solution.
  1. COAXIAL INDICATOR
    By tjd10684 in forum MetalWork Discussion
    Last Post: 01-18-2019, 12:51 PM
  2. LED indicator
    By neric in forum CNC Machine Related Electronics
    Last Post: 11-17-2011, 11:59 AM
  3. Replies: 11
    Last Post: 02-28-2010, 08:33 PM
  4. Best Coaxial indicator to buy?
    By aaron p in forum Community Club House
    Last Post: 03-05-2009, 08:30 AM
  5. Dial indicator
    By hkrok in forum News Announcements
    Last Post: 08-17-2007, 01:49 AM
