586,116 active members*
3,469 visitors online*
Thread: calculator
Results 1 to 9 of 9
    Jan 2008
    8
    calculator
    Using bobcad 20.6, Is there a built in calculator to do math with? If there is i can't find it. Using windows but when i click on drawing it goes to tray, need one to stay on drawing so i can enter #s ?
    Thanks for your help!!!!!!!!!!!
    In V25 you can enter mathematical expressions in BC input boxes, i.e. if you have to put in a Radius but know the diameter is 55.36729 you can enter 55.36729/2
    Not sure about earlier versions though,
    - Nick
    May 2013
    701
    I just checked My V20.7 and it does calculate
    RAF
    Jun 2007
    3757
    Quote Originally Posted by whaley View Post
    If you don't have the windows maximized, you can click between windows. Maximize once done with the calculations.
    Have you ever used Alt-tab? Calculator in focus, sitting on top of CAD screen.
    Enter the numbers. Right click in calculator display, Copy for pasting, Alt-tab, and the CAD cursor will still be where you left it.
    Keyboard shortcuts are often much better than the random input device; the mouse;
    Or go overboard, and run 2 screens. They are such low cost items these days.
    Sep 2012
    1195
    This calculator has the ability to keep the window on top, so when you go back to Bobcad, it will still be visible:
    Free calculator software - Moffsoft FreeCalc is a great replacement for your Windows calculator.
    As with all software, read the license agreement carefully. I believe that it says that it can't be used for commercial purposes, so if that's your intent than perhaps you'll need to contact the developer and obtain a license to do so. Otherwise, it works quite well.
    Jan 2008
    8
    Thanks for the help, using BC for 30 years, v14/v22. v22 is such a change from v20 i never use it. most my work is 2D just for my own projects!!!!!!!!!!!!!!!! I know where to come for help!!!!!!!!!!!!!!!!! Thanks again to all !!!!!!!!!!!!!!!!!
    Mar 2010
    1852
    I use the calculator in the feature box all of the time, it is very easy and useful. If you don't know, you can't do multiple calculations at once ( 5*5+3/2) but if you do one like 67/3 then move the cursor out of the box, it will do that calculation and then you just move the cursor back into the box and enter your next figures. That way you can do chain calculations. It is very fast that way
    Mike
    Dec 2008
    4548
    If someone STILL wanted to run the windows calculator on top, you could use something like AutoIt or autohotkey and make a script that launches the calc.exe with always on top. You can even make an "exe" out of the script, that would be your launcher instead of running the batch file.
    Jan 2008
    8
    Quote Originally Posted by Machineit View Post
    Mike
    It will do (5*5+3)/2 =14 but you have to add the brackets, like you say its faster to just enter 2 times.
  1. geometry calculator
    By groguide in forum Mechanical Calculations/Engineering Design
    Last Post: 01-14-2013, 11:24 AM
  2. Calculator
    By t512857 in forum Employment Opportunity
    Last Post: 03-19-2012, 08:17 AM
  3. machinist calculator
    By FUBAR62172 in forum Community Club House
    Last Post: 06-23-2010, 02:18 PM
  4. Looking for a threading calculator
    By northernmach in forum MetalWork Discussion
    Last Post: 12-09-2006, 02:01 AM
  5. CNC Axis Calculator
    By MrBean in forum Coding
    Last Post: 09-17-2006, 12:19 PM
